Ceramic Pads? - Mustang Evolution
Old 07-06-2012, 05:24 PM   #1
austinknoll's Avatar
Ceramic Pads?
would ceramic pads work on stock rotors? will it make a nasty noise when i apply the brakes? i currently have part ceramic pads and they have an annoying squeal when i brake and they produce an abnormal amount of brake dust. any way to fix this? or just buy different pads?
thanks
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 07-06-2012, 05:29 PM   #2
Stang.racr's Avatar
They are fine. Your pads must just be shot. Usually they produce less brake dust
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-07-2012, 01:05 PM   #3
Re: Ceramic Pads?
the pads squeaked since i installed them about 4 months ago
65 Mustang coupe
Old 07-07-2012, 03:06 PM   #4
Mile high JDF's Avatar
The squeaking is normal. Ceramics have a higher metal content in them, hence the reason they squeak and stop better. If the squeaking bugs you then buy a non-metallic pad.
---------- Post added at 09:06 PM ---------- Previous post was at 09:05 PM ----------
They also create more dust
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-07-2012, 10:11 PM   #5
The thing is my half ceramics produce a lot of dust. So idk what the problem is. After 3 days the wheel is very black
65 Mustang coupe
Old 07-07-2012, 10:45 PM   #6
That's normal
---------- Post added at 04:45 AM ---------- Previous post was at 04:14 AM ----------
Correction, it has less metal content. However the compounds used just create more dust and noise. Than normal pads.
Old 07-08-2012, 11:52 AM   #7
That's normal
Okay thanks and ceramic pads will lower the brake dust but increase the squeal noise? Correct?
65 Mustang coupe
Old 07-08-2012, 12:35 PM   #8
Not necessarily, the brake dust is what mostly causes a squeal noise and most aftermarket pads seem to produce a lot of brake dust. A lot of it just depends on the brand.
Old 07-08-2012, 08:41 PM   #9
I bought brake best half ceramics thinking they would be quiet but boy was I wrong haha. The brake dust though is crazy compared to my old pads
65 Mustang coupe
Old 07-08-2012, 08:46 PM   #10
Yeah I know the feeling. If you can, take apart the bakes and try and blow out the dust. It should help the squealing a bit.
Old 07-08-2012, 09:04 PM   #11
McNassty's Avatar
Try BAER Decelaotors and Decelarotor pads, I have them and have noticed no noise and very low brake dust.
McNassty is offline   Reply With Quote
Old 07-11-2012, 10:38 AM   #12
I think I'll do that today because these brake best pads suck haha. If I go down a 20 mile trip and back the rims have a decent amount of dust on them
---------- Post added at 11:38 AM ---------- Previous post was at 11:38 AM ----------
I'll try those. Are those ceramic or half ceramic?
65 Mustang coupe
Old 07-12-2012, 10:35 AM   #13
McNassty's Avatar
Ceramic
Old 07-12-2012, 02:49 PM   #14
Ceramic
Do you have stock rotors?
65 Mustang coupe
Old 07-13-2012, 10:20 AM   #15
McNassty's Avatar
Nope, I have the drilled and slotted Decelarotors
Old 07-15-2012, 11:49 PM   #16
1slosix's Avatar
Re: Ceramic Pads?
I run Hawk Ceramic pads and love them for the money...i'm guessing you have a semi-metallic pad op and not a true ceramic since you're having dust issues and squeaking...they have a nice bite but don't keep things nice and clean. time to upgrade
12:33 AM
