Fact or Fiction - Mustang Evolution
Old 03-10-2008, 03:49 PM   #1
iwannagofast's Avatar
Fact or Fiction
i was told that ford has a different electrical system that all other cars. I was told that when working on a ford you HAVE to put the battery termanial on the opposite way you took them off or eles it will reverse the cars polarity and will throw alot of electircal things off. Is this true? because i find it hard to believe.
iwannagofast is offline   Reply With Quote
Old 03-10-2008, 04:02 PM   #2
Re: Fact or Fiction
Sounds like a bunch of bs to me...
Old 03-10-2008, 04:16 PM   #3
Re: Fact or Fiction
I've never done that
Old 03-10-2008, 04:52 PM   #4
Re: Fact or Fiction
... maybe that's what went wrong...
Old 03-10-2008, 05:01 PM   #5
Re: Fact or Fiction
:dunno: Could be
Old 03-11-2008, 07:20 AM   #6
Re: Fact or Fiction
I am not sure what you mean by reverse the pos and neg wires vs other cars... the positivie HAS to go on the positive line and the negative HAS to go on the negative line, there is no such thing as reversing them.
Old 03-11-2008, 07:36 AM   #7
shamdoodie's Avatar
Send a message via ICQ to shamdoodie Send a message via AIM to shamdoodie Send a message via Yahoo to shamdoodie
Re: Fact or Fiction
i thought the OP was talking about if you take the pos cable off the battery first, then the negative, you will HAVE to put the negative back on first then the positive or else it will cause damage... regardless, i have never heard of that before but im no mechanic.
drive it like you stole it... just dont wreck it.
shamdoodie is offline   Reply With Quote
Old 03-11-2008, 10:46 PM   #8
Re: Fact or Fiction
yea shamdoodie, thats what i mean.
Old 03-11-2008, 10:50 PM   #9
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: Fact or Fiction
All the service manuals tell you what order to remove and reattach the cables, but I've never seen it matter. I just connect 'em up however I grab 'em.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 03-11-2008, 11:10 PM   #10
Scut95's Avatar
Re: Fact or Fiction
you should remove the neg first then the pos.....when puttin them back on put the pos on first and neg last....thats for all cars
Old 03-12-2008, 01:10 AM   #11
OsirisGuy's Avatar
Re: Fact or Fiction
Since the '50's (GM until the early '70's) most car manufactures have adopted a negative chassis meaning the chassis acts as a ground for the whole car. Current always flows from negative to positive, from the anode to the cathode. The only way to reverse the polarity for a car is if you were to switch the battery terminals where the original negative lead is connected to the car's wire positive lead wire, in which case current wouldn't flow and could cause electrical damage to the car. If you notice on your battery and follow the positive and negative leads, your negative will ground directly to the chassis, most likely right under the battery or in the engine compartment and the positive will run into your firewall and all the other electrical components under your hood.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
M112 V6: Fact vs Fiction LilRoush Pre-2005 V6 Mustang 145 01-05-2009 05:21 PM
This must be fiction... MarkuzLS1 The Bar 17 11-10-2007 07:26 AM
The 9/11 Conspiracies: Fact or Fiction JROC The Bar 11 11-05-2007 11:06 AM
Calling All Pulp Fiction Fans likwuddeath06 Pictures and Videos 2 09-21-2007 10:39 AM
MAF FACT or FICTION 70mm stock eagle05 1979-1995 Mustang GT 12 09-06-2006 09:56 AM
11:34 PM
