any way to fix cracking coat on headlights? - Mustang Evolution
Old 09-18-2012, 02:19 AM   #1
austinknoll's Avatar
the clear coat on the headlights are cracking and coming off, is there any way to recoat it? like a spray or am i just screwed? haha the headlight itself is in good condition, its just the exterior protective coat is coming off and i would like to not buy new headlights.
if anyone has this problem chime in!
thanks guys!
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 09-18-2012, 04:26 AM   #2
jdavis96gt's Avatar
Region: West Virgina
Re: any way to fix cracking coat on headlights?
Sand it and clear coat it. Just Google it. I read about it couple months ago
Old 09-18-2012, 09:44 AM   #3
Have you ever tried it? I just read that too but I've also read that the polish continuously needs reapplication
65 Mustang coupe
Old 09-18-2012, 05:49 PM   #4
1slosix's Avatar
if you sand it and go at it with a rubbing compound you'll get it as good as you're gonna get. start with an 800, then 1200, and then a 2000 grit...you're taking that top layer off basically..then you polish like crazy with a compound ( i like meguiars scratch x )
carving corners like a boss
Old 09-20-2012, 12:37 PM   #5
If you want to do it quick, dirty and easy get 2 polish wheels from harbor freight, stick it on the end of your drill, after you tape off the paint around the headlights buff away with a rubbing compound, then with a polishing compound on the 2nd wheel...should take all of 30 minutes and will last about 6 months...I have done this many times on many cars. works great.
If you're worried about having to run the buffer over it every now and then replace them.
you'll be looking for this type of pad for a drill/ may need to buy and adapter...still very cheap. (the one pictured is for a bench grinder)
Abrasive Discs & Wheels - 5 piece 6 25 ply 1/2 Arbor Bench Grinder Buffing Polishing Wheels
JUNIORS08GT is offline   Reply With Quote
Old 09-20-2012, 06:58 PM   #6
[QUOTE="JUNIORS08GT"]If you want to do it quick, dirty and easy get 2 polish wheels from harbor freight, stick it on the end of your drill, after you tape off the paint around the headlights buff away with a rubbing compound, then with a polis
65 Mustang coupe
Old 09-21-2012, 02:53 AM   #7
Could I do it on the cracked part or do I have to sand the whole thing
65 Mustang coupe
Old 09-21-2012, 10:35 AM   #8
do the whole thing the results will be much cleaner and not look choppy...you"ll get a nice even finish.
Old 09-21-2012, 05:30 PM   #9
I think I might just go buy some dark 01-04 headlights, I hate the chrome ones now
65 Mustang coupe
07:24 PM
