Fog light confusion. - Mustang Evolution
Old 09-18-2012, 01:27 PM   #1
Bamman's Avatar
I have a 2000 v6 mustang and I have a set of gt fogs and I had a sperate switch powering them for awhile but now something happened and they didn't work and now I was wondering if I could just go a splice them into the running lights or the amber part of the head light when ever I turn it on. I've looked up and down for diagrams but I couldn't find anything if any one has ever done this or if some one can find a diagram can you send the link it would be much appreciate.
8 Cylinders Little Brother.
Bamman is offline   Reply With Quote
Old 09-18-2012, 05:47 PM   #2
1slosix's Avatar
Re: Fog light confusion.
yes this is how i wired my last two sixxers up. run each fogs power wire to the constant power wire on each amber and run the ground to the headlights ground bolt (one just behind each headlight).
carving corners like a boss
Old 09-18-2012, 06:04 PM   #3
Bamman's Avatar
Which wire is the constant wire?
Old 09-18-2012, 07:46 PM   #4
1slosix's Avatar
turn your ambers on and take a test light to each wire...honestly it's been so long since i did mine i forgot the color wire. i'll check tomorrow for you though
Old 09-18-2012, 08:02 PM   #5
Bamman's Avatar
Ok thanks for that!
Old 09-19-2012, 06:45 PM   #6
Bamman's Avatar
Bump.
Old 09-19-2012, 10:53 PM   #7
1slosix's Avatar
yeah sorry i got busy and forgot..ill write myself a note to check in the AM
Old 09-19-2012, 11:08 PM   #8
Bamman's Avatar
No rush at all! Just seeing if any one else knew too.
Old 09-20-2012, 07:44 PM   #9
Bamman's Avatar
Bump
Old 09-21-2012, 06:57 AM   #10
Bamman's Avatar
Bump
Old 09-22-2012, 08:45 AM   #11
Bamman's Avatar
Bump
Old 09-23-2012, 09:03 AM   #12
Bamman's Avatar
Bump
Old 09-24-2012, 10:21 AM   #13
Bamman's Avatar
BUMP!
Old 09-25-2012, 09:35 AM   #14
Bamman's Avatar
Bump!
Old 09-26-2012, 12:51 PM   #15
Bamman's Avatar
BUMP!!!
Old 09-26-2012, 01:53 PM   #16
Rm360's Avatar
I believe the wire is brown, to be sure you should either do what 1slosix suggested get a test light and test it, or get a manual for your car , both are a good investment .
Old 09-26-2012, 10:50 PM   #17
Bamman's Avatar
That's what I'm confused with is how do I light test it?
Old 09-28-2012, 08:28 AM   #18
Bamman's Avatar
Bump.
Old 09-28-2012, 08:46 AM   #19
Rm360's Avatar
http://autorepair.about.com/od/troub...rcuit-tstr.htm
Old 09-28-2012, 09:37 AM   #20
Bamman's Avatar
No its not even that, I just wanna know which wire from the running lights is positive so I can slpice it into there.
Old 09-28-2012, 09:42 AM   #21
Rm360's Avatar
Turn on the running lights and use the test light to find it , open the hood find the plug connectors behind the headlights and start testing the wires the one that's positive will light up
04:49 PM
