Window magic - Why? - Mustang Evolution
Old 09-27-2012, 05:00 PM   #1
BlackHorse1911's Avatar
Window magic - Why?
Why do the windows go up like that when you close the door? I have always wanted to know that..
BlackHorse1911 is offline   Reply With Quote
Old 09-27-2012, 05:08 PM   #2
It's not me, it's you.
primer2tone's Avatar
It's to protect the window weather striping at the top of the door frame.
I used to have a 2 door dodge avenger and sometimes when you shut the door the window would not go under the weather stripping, it would sit on top and I would have to open the door again and shut while holding the window in place.
Old 09-27-2012, 05:22 PM   #3
Ohhh.. Ford is smart.
Old 09-27-2012, 05:25 PM   #4
Whitelightning's Avatar
I've read also it prevents the window from breaking because on the older models there was nothing that really kept the glass stabile and some rare cases the glass would hit and break. Least, that's what happened on my friends 98.
Old 09-27-2012, 06:18 PM   #5
aegischief's Avatar
Also allows for the windows to fully seal when closed which in turn reduces wind noise.
aegischief is offline   Reply With Quote
Old 09-27-2012, 07:19 PM   #6
Blogger
99ford's Avatar
^ yes it creates a weather tight seal and works to pressurize the cabin learned that from infinity.
Old 09-27-2012, 08:15 PM   #7
Other cars do it too.
My Mini Cooper did it as well as my friend Jack's Porsche. You just do not want to push the door shut using the glass. Use the door handle or the door but never the glass.
You really got to watch your passengers when they get out and tell them not to use the glass to close the door.
There is no upper frame on these type of windows and pushing on the glass can cause a lot of wear and tear and loosen the glass in the channel giving you all sorts of problems in time.
Old 09-27-2012, 09:45 PM   #8
Blogger
99ford's Avatar
Never thought of that, but I never close a car by it's glass. haha weird that I think of it now. I guess after owning 2 convertibles it's second a nature
Old 09-28-2012, 01:59 AM   #9
Geez! How hard was your friend shutting his door? Lol
Old 09-28-2012, 06:41 AM   #10
Her* and she put her hand on the glass and just closed the door and it hit the weather stripping and cracked it to hell and back
Old 09-28-2012, 07:21 AM   #11
Keep doing it and it will happen.
If you are extremely very lucky it will be just fine closing the door by using the window glass.
**************************BUT***********************
If you are like the other 99% either you will have a problem such as the window will not work at all, a broken window, or the dreaded out of sync meaning the window will not go all the way up or all the way down until it is reprogrammed.
It is all to easy just to use the door handle
A little harder to train your passengers to do the same.
'99 Window Leak? Smiley Pre-2005 V6 Mustang 4 02-02-2012 07:53 PM
Help window tint messing up 98projectpony General Mustang Discussion 2 12-20-2011 04:11 AM
Window tint MVP u eNVy ME Mustang Paint, Appearance & Detailing 19 09-11-2011 09:11 AM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
12:42 AM
