I Can't Believe This! Has It Happened To You? - Mustang Evolution
Old 10-09-2012, 12:50 PM   #1
SCCofSV's Avatar
I took my car to Galpin Ford, to find out exactly where the noise is coming from, what's causing it. The service mgr. takes a ride and says it sounds like a Rear wheel Bearing. A friend tells me her roommate just happens to be a recently retired Ford Mechanic of 35 years. After he takes a drive in my car, he tells me LH Rear Wheel Bearing but, it could be a Pinion bearing. Since he wasn't sure, I got two other opinions. Both of which said, "Rear Wheel Bearings."
So, the Rear Wheel Bearings win by default! I take it back to the dealer and tell them I wanted to replace BOTH Rear Wheel Bearings. Sounds pretty cut and dried, right?
I'm told, it will take about two hours and will cost approximately $200.00 + parts $33.00 x 2. No problem! Ha!
After 3 hours, I get called over to the service bay, to see my car, wheels still on but, the Differential cover off. (I just replaced the Gear Oil w/Royal Purple 2 days before which the knew). I assume I'm being called over there to be asked which gear oil I want in there. WRONG! They haven't even touched the wheels! So, I specifically said, "You didn't have any problems changing the Rear Wheel Bearings, did you?" The mechanic looks at me and says, what? He must have known I was about to blow it, because he backed up a step! I look around No boxes of new bearings anywhere. He's telling me that I need to have my Pinion bearing replaced because it's loose! He moves the driveshaft and the pinon bearing move about 1/5000th of an inch. I lost it! Did I over react? And then hands me an estimate of $1278.68! WTF???
REAR DIFFERENTIAL OVERHAUL BEARINGS $977.68
REAR BRAKES pads $186.00
REAR AXLE DIAGNOSTIC $115.00
Where is the Rear Wheel Bearings I want replaced? That was the reason I went there! So, I'm told to going back while to the waiting room. I was there there waiting for 6hours! When I was called back to my car, NO one was around, everyone had gone home! But, 1 wheel had been removed.
Please tell me, what do I do?
ID:	71638   Click image for larger version
SCCofSV is offline   Reply With Quote
Old 10-09-2012, 01:20 PM   #2
check your local laws, unless you gave them permission to perform some labor/replacement on your car they cant. They have to many times give you an up front quote as well as get your permission. Of course they can always pull the "you said we could" bs.... but I would check the local laws on this.
Old 10-09-2012, 02:27 PM   #3
Gil_T2's Avatar
I don't see a problem, they had to remove the rear diff cover to pull the C-clips so they could remove the axle bearings. He just happen to discover that you pinion bearing was bad , not the axle bearings. Just because they though the axle bearings were bad , they still need to make sure that is what was really the problem. What would you have done if they replaced the wheel bearings, and you drove off only to hear the same sound? You would have been pissed that they did not discover the real problem.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 10-09-2012, 04:34 PM   #4
I do see a problem, that price jump is outrageous. A thousand dollars over the original estimated cost.
I would not get overly excited about the need for more than 1 or 2 wheel bearings being replaced though, because if one fails and spreads metallic particles all through the rearend you should expect to possibly have to replace all of the bearings. Personally I would replace all of the bearings and seals if it were my car, but then I do all of my own repairs, so the labor would be nil.
Price all 5 bearings and 3 seals yourself (2 axle, 2 carrier and 1 pinion bearings, 2 axle and 1 pinion seals) and see what they cost, then find out how much time is needed to replace them, then add up their cost per hour for labor. I'm afraid you might find out that the cost is within reason for the labor rates in your area, or it may be way off.
Old 10-09-2012, 04:54 PM   #5
Gil_T2's Avatar
The original estimated cost was for a different repair. It is no different than getting a price on brake pads, then finding out you need calipers and rotors. Service writers don't have a Crystal ball. And the mechanic called him out to look at the car BEFORE pulling it apart, He could put the cover back on, fill it with oil and go somewere else if he wanted too.
Old 10-09-2012, 07:30 PM   #6
Yes, I know that and I agree with you. My post wasn't meant to be in disagreement with you. Sorry I wasn't clear and that you misunderstood.
Who wouldn't have a mad panic attack though, when confronted with an estimate that had grown in size that much.
I guess if you don't know how and cannot check it to see for yourself, you are stuck with either getting it done or taking it somewhere else for another opinion.
Here is the cost for a complete bearing kit. - $74.99 at American Muscle
Makes you wonder how they came up with $977.68 doesn't it?
Surely it does not take $900 worth of labor to install the bearings?
I have seen numerous cases over the years where mechs, especially at dealerships, have tried to pull shady crap just to inflate a bill too, which is why I work on my own stuff when I can and when I can't I have people locally that I trust, who will take care of issues for me when I cannot. One of the benefits of living in a small community.
Old 10-09-2012, 07:41 PM   #7
V6 stang's Avatar
Sounds like me.. Went in to get a 25$ oil change.. Came out with a 928$ bill from a new oil pan cuz the one I had the plug was stripped out. I was mad.
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 10-09-2012, 07:47 PM   #8
That's exactly the kind of crap I'm talking about.
No way should it cost that much to just replace an oil pan.
Old 10-09-2012, 08:09 PM   #9
Sirtat's Avatar
that's nothing lol I just took my 2010 corolla to the dealership I bought it from because there was a rattle on start up ( cam tensioner ) recall ! so I take it in they replaced the tensioner and said they cracked the tensioner bracket... loaner car for 4 days I got it back 15 min before closing on a Saturday drive it home and it starts sounding like a diesel so I take it back and well let there work order explain the rest... ya motor came out and cam bearings for got to go back in !!!
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 10-09-2012, 08:22 PM   #10
Blogger
99ford's Avatar
That's pitiful! Shop around I find Ford to be insanely high on something's.
Old 10-09-2012, 08:42 PM   #11
Just looking at the pic of the wheel bearings,,they look ok to me,,it may be the pinion
---------- Post added at 08:39 PM ---------- Previous post was at 08:35 PM ----------
I agree i even grew up fixing my own stuff,,sometimes it when south,,but usually i try again until i get it right..Hell for that price I think he can buy one all ready to install..
---------- Post added at 08:42 PM ---------- Previous post was at 08:39 PM ----------
What..You can drill and retapp the drain plug,,thats crazy,,I done a bunch because of the jiffy lubes strips them out a lot
mymustang is offline   Reply With Quote
Old 10-10-2012, 07:27 AM   #12
V6 stang's Avatar
It already had one of those temporary ones you put it there and that had broken. I forget the name of the thing but the pan was done.
What could I do tho? My car was stuck in their shop without an oil pan on lol. They couldn't find one at a junkyard cuz ford changed over to a different oil pan one month after my car was made.. Brand new it was expensive.
Roush Exhaust
Old 10-10-2012, 10:24 AM   #13
check your laws, as I said some states require you to approve any additions or changes to what you agreed on so they cant just go replacing stuff without your consent.
Old 10-10-2012, 10:57 AM   #14
Gil_T2's Avatar
Don,t think that is relevant, he was shown the parts and given new price before repairs. YES, i do think price is high, I would have paid for diagnoses and had car put back together and left
Old 10-11-2012, 04:14 AM   #15
Ive seen a repair that looked like a sheet rock anchor,,that has the wings on it ,,they push it through the drain hole,,and the wings pop open and then you tighten it up against the pan,,I hate to see people get ripped,,Alot of times oil change places use air ratchets to remove the plugg,,which stripps out the plug..You wouldnt believe the crapp ive seen that people use for drain plug repair
Old 10-11-2012, 09:33 AM   #16
claudermilk's Avatar
This is why I do it myself.
claudermilk is offline   Reply With Quote
Old 10-11-2012, 10:20 AM   #17
V6 stang's Avatar
Well good thing is I got a warranty on it so they don't do **** on purpose to it for a year hehehe
Roush Exhaust
07:31 AM
