Anyone else have problems with wheel spin? - Mustang Evolution
Old 10-09-2012, 03:38 PM   #1
Ive finally broken in my 2013 Boss and started doing some conservative WOT pulls. Anyone else have traction problems?
I was playing around in first and i get a TON of wheelspin if i just floor it from a dig... I did different pullls from 5 mph, 15 mph, and 25 mph and theres less wheel spin, but its still there.
Even in 2nd gear i it feels like i lose traction alot.... 3rd isnt a problem but by then im going like 60 mph
I remember a week or so ago i was looking for the traction control button and pushed it when i found it. I pushed it again to turn traction control back on but maybe something is wrong and it never turned back on?
I dont really have anything to compare it to though since i never floored it before. Anyone else have the same problem?
dark mod is offline   Reply With Quote
Old 10-09-2012, 04:15 PM   #2
McQueen's Avatar
I have the same thing happen to me with my 13, it could be the 3.73 gears, when i launch hard i get wheel spin 1 to second and third.
First time i did a hard launch all i did was a really long and Embarrassing burnout
McQueen is offline   Reply With Quote
Old 10-09-2012, 04:20 PM   #3
McQueen's Avatar
As long as u dont do this!!!!
Old 10-09-2012, 04:25 PM   #4
Black5.0's Avatar
I think I know what the problem is.....too much horsepower! Trade it in for a Prius and you should solve that
Black5.0 is offline   Reply With Quote
Old 10-09-2012, 04:30 PM   #5
03whitey's Avatar
Its called turn traction control off and buy sum real tires lol Mickey Thompsons! Then dead hook. Traction control turned on kills your power dude
03whitey is offline   Reply With Quote
Old 10-09-2012, 04:56 PM   #6
yeah, I have the wheel spin "problem" all the time ...
mmike87 is offline   Reply With Quote
Old 10-09-2012, 05:14 PM   #7
Tominkc's Avatar
Send a message via Yahoo to Tominkc
I'm always spinning tires from 1st thru 4th if I floor it everytime I let the clutch out!!
Tominkc is offline   Reply With Quote
Old 10-09-2012, 05:33 PM   #8
03whitey's Avatar
When you dead hook you do this
Old 10-09-2012, 05:48 PM   #9
nosympathy's Avatar
same, i just drive my car enough I have learned how to cope with it.
Old 10-09-2012, 05:50 PM   #10
2012Vader5.0's Avatar
Throttle control. if you floor it every time and you spin, slow down how quickly throttle is being introduced. Tires do help though.
2012Vader5.0 is offline   Reply With Quote
Old 10-09-2012, 06:28 PM   #11
SolidRRaxle's Avatar
Cope? No... People cope with minivans because they have kids or with 4 cylinders because of gas prices. Just sayin
In retrospect, that was kinda a fuk response... Just meant its kinda a good problem to have
SolidRRaxle is offline   Reply With Quote
Old 10-09-2012, 07:10 PM   #12
McQueen's Avatar
What slicks would fit the brembo rims????
Old 10-09-2012, 07:14 PM   #13
03whitey's Avatar
Get some drag radials man
Old 10-09-2012, 07:31 PM   #14
gtstyles2's Avatar
Maybe it's just me, I have 3.31 gears... This is my 1st Mustang, I guess I don't feel that powerful low end torque that makes the wheels spin... Maybe 3.73 in the future?
Old 10-09-2012, 07:44 PM   #15
nosympathy's Avatar
I meant coping as in I have learned how to throttle control the 5.0 beast that it is. I am not unhappy by it at all.
I had 3.31 gears factory on my car, and changed them out to FRPP 3.73 gears because the 3.31 gears felt docile. Not that the car is, but starting off the line felt weak. I had the gear change done on a rainy day, and lost traction multiple times on the way home from not being used to the gearing, while babying the gears, as in not breaking 3k rpm, so they would break in! (I don't know that you really have to break them in, and probably don't, but I was recommended that if I could I should, so I did.)
***edit*** just to note, I based it feeling sluggish off the line, by driving my dads 2007 tundra, and my uncles 350Z. Both felt quicker initially off the line, even though I would easily overtake them. Both of those cars rated at around 6 second 0-60 and the mustang much less. Now I both beat them off the line, and leave them in the dust.
Old 10-09-2012, 08:03 PM   #16
Bladezx's Avatar
I've spun my tires from 1st to 6th and that's with good tired
Bladezx is offline   Reply With Quote
Old 10-09-2012, 08:28 PM   #17
Since I got my tune and Steeda CAI I can stomp on it in first with 3.31's from a slow roll and easily break the back tires loose .... 255's.
I found out when testing the car after uploading the tune ... normally it didn't spin like that ... it would just go like a bat out of hell. Now, it does both.
Old 10-09-2012, 08:34 PM   #18
03whitey's Avatar
Yes you should def. give your gears a "break in period" just so they can get proper wear pattern, thats why you should be real cautious on buying a used set of gears!
Old 10-09-2012, 09:52 PM   #19
Loc: Austin,TX
Better tires and feather it a little. It took me a bit but I can easily chirp all the way through 4th now.
Old 10-09-2012, 10:57 PM   #20
+1
Old 10-09-2012, 11:13 PM   #21
I did a little more research and i found out that adjusting the suspension helps with this. Factory setting is 2, and 5 is the stiffest. People reported that adjusting them to 3.5 reduces the wheelspin alot.
ill give it a shot and report back
Old 10-10-2012, 12:25 AM   #22
Lorraine's driver
ab_mach1's Avatar
The softer your suspension is the better. This will allow your body weight to shift to the rear, more so than it would at the stiffest setting. This will give you a better launch. If 1 is the softest, try 1.
You might as well forget about street tires if your looking for great launches. Drag radials was suggested^, and that is your best bet. You'll have to get new wheels if you wanna runs slicks. Plus, you'll have to put them on once you get to the track because they are not street legal, drag radials are.
Without several modifications to your rear suspension, and at least drag radials, you'll never be able to do a high RPM clutch dump. Practice your launches and you'll get much better at it.
Instagram: @ab_mach1
Old 10-10-2012, 02:58 AM   #23
DaBluedude's Avatar
I only have traction problems through first second and third gears... Bahahahahaaha. Such a good problem to have.
2003 Mach 1
05:18 AM
