Warped Rotor? Help. - Mustang Evolution
Old 10-15-2012, 05:06 PM   #1
sLbxO143's Avatar
Warped Rotor? Help.
When I turn my steering wheel either left or right it makes a little clicking noise and then when I was pulling into my driveway today and slowing down I heard a rattling noise come from the front wheels. My brake pedal also putters a little bit, but I think It may be the front rotors or pads ..help
sLbxO143 is offline   Reply With Quote
Old 10-15-2012, 06:35 PM   #2
jdavis96gt's Avatar
Region: West Virgina
Turning your wheel should have nothing to do with brakes.
Old 10-15-2012, 09:10 PM   #3
If the brake pedal fluctuates, then it likely is a warped rotor.
The clicking you hear may be from the same cause as the rotor rubs against the brake pad because it is warped and you hear it when turning likely because you have slowed down to turn.
Old 10-15-2012, 10:04 PM   #4
fomoco4life's Avatar
Bad bearings often = clicking
Old 10-16-2012, 10:05 AM   #5
sLbxO143's Avatar
Thanks for help guys! Getting it looked at this weekend, ill let you know what it turns out to be
Old 10-16-2012, 10:35 AM   #6
Dub9stang's Avatar
Jack the front end up and just wiggle the front wheels and check for play. Simple and quick check
Dub9stang is offline   Reply With Quote
Old 10-16-2012, 10:48 PM   #7
Lightbulb
To elaborate:
With front end jacked up, and jack stand under frame, pull back and forth on wheel at 9 o'clock and 3 o'clock. If there is play, then repeat at 12 o'clock and 6 o'clock. If there is play in both positions, wheel bearings are loose or bad. If only at 9 and 3, then tie rods or steering rack have play.
That is the simple answer, it can get much more complicated.
Don't forget to also do the simple check for worn out brake pads...
Good Luck!
FluxPrism
FluxPrism is offline   Reply With Quote
Old 10-17-2012, 10:49 AM   #8
Dub9stang's Avatar
Originally Posted by FluxPrism
To elaborate:
Good Luck!
FluxPrism
Lol you didn't like the way I explained it?
Old 10-17-2012, 11:21 AM   #9
Flux is a detail man...lol
Old 10-17-2012, 12:13 PM   #10
sLbxO143's Avatar
Details are good lol, but I appreciate all of the help😊
Old 10-17-2012, 08:52 PM   #11
sLbxO143's Avatar
Happened to be a warped rotor and worn pads, also need a wheel bearing on the passenger side. Thanks for all the feedback on the this thread.
Old 10-17-2012, 09:02 PM   #12
Talking
I'm sure that wasn't cheap, but just replacing that wheel bearing before it let go saved you a ton of money and headache! And changing out that warped rotor will give you better stopping capability, maybe (OK, it's a stretch...) saving you from an accident.
Got to look on the bright side!
FluxPrism
Old 10-17-2012, 09:09 PM   #13
sLbxO143's Avatar
FluxPrism
I agree, I don't mind spending the money because it better than something worse happening like an accident. I had a very bad accident with my last car so now when it comes to tires and brakes I get worried easily. Lol so better safe than sorry
05:01 AM
