Drag Racing - Mustang Evolution
Old 10-30-2012, 09:27 PM   #1
Drag Racing
I have a 71 maverick body that is set up for a small block ford with no engine and trans. Could I pull the engine and trans out a 2002 mustang gt and use that? Or would a engine and tran be better out of a 1993 mustang? Suggestions? Tips?
Caveman681 is offline   Reply With Quote
Old 10-31-2012, 11:01 AM   #2
claudermilk's Avatar
Anything is possible with enough money, time, and skill.
I would think the new cammer engines would be a really tight fit. I know it's quite tight in my project car--'73 Pinto with a 351W, and that is with smaller pushrod heads. IIRC, basically the same platform. I would think fender wells will need to go & hood might (probably) would need to be a cowl one. I would also anticipate cutting out the engine mounts & replacing them if they are for a Windsor block--I'd be surprised if the modulars have the same mounts.
claudermilk is offline   Reply With Quote
Old 11-17-2012, 04:16 PM   #3
08SteedaQ350's Avatar
08SteedaQ350 is offline   Reply With Quote
Old 11-17-2012, 04:21 PM   #4
tc x 4's Avatar
A pre 84 motor would be the easiest.
10:42 AM
