5w-20 vs 5w-30 - Mustang Evolution
Old 11-10-2012, 08:41 AM   #1
Ravnus's Avatar
5w-20 vs 5w-30
I have always used Mobil 1 5/20 since my second oil change. I have 17,000 miles. Typical Coyote motor...i go through a quart every 1200 miles. Today, i switched to 5/30 my mechanic said the heavier oil might help with the consumption. Although it feels slower, is it me??
Ravnus is offline   Reply With Quote
Old 11-10-2012, 09:46 AM   #2
CorDog009's Avatar
The heavier oil might help some with consumpton, but I'd be concerned with the thicker oil trying to go through the passages for the VVT. IMO I'd install an air/oil separator on the passenger side pcv and just let it catch the oil.
On my LS1 cars, a lot of us switch to Mobil 1 5/40 and it helped a lot, but that's an entirely different engine, but still gives you an idea. Before 5/40 my air/oil separator would catch probably 3x the amount of 5/20 or 5/30.
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
Old 11-10-2012, 10:20 AM   #3
Struego's Avatar
You may notice a difference in mpg. 5w30 will generate more friction.
Struego is offline   Reply With Quote
Old 11-10-2012, 10:27 AM   #4
Region: Montana
This would be your best indicator . A different brand, if used, may affect your car as properties vary.
"OLD AGE AND TREACHERY WILL OVERCOME YOUTH AND SKILL"
manicrodder is offline   Reply With Quote
Old 11-10-2012, 10:46 AM   #5
The Blue Dragon
GrabberBlue5.0's Avatar
According to Ford, 5w30 is just fine, I'm running it and noticed less oil consumption and no loss of power, it's probably just in your head
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 11-10-2012, 11:34 AM   #6
SSC182's Avatar
5w-30 will not hurt your VVT solenoids or cause you to get any noticeable MPG change its perfectly fine for your car. If its burning a quart every 1200 miles that exceeds fords standard of a quart every 1500 so I'd get it looked at. And if they tell you it's a quart every 1000 they are lying to you fords is 1 for 1500.
SSC182 is offline   Reply With Quote
Old 11-10-2012, 12:55 PM   #7
30 is fine ... remember, Track pack cars use 5w-50 and the engines are the same with only the addition of an oil cooler and upgraded radiator.
mmike87 is offline   Reply With Quote
Old 11-10-2012, 01:11 PM   #8
That weight is fine,,just DONT change the first number,,you need that 5 to get to the top at start up
---------- Post added at 03:11 PM ---------- Previous post was at 03:09 PM ----------
They say ford recommends 5 w20 ,and 5w30 may drop your fuel mileage,,I would use synthetic personally..I use 5w30 mobile 1 synthetic
mymustang is offline   Reply With Quote
Old 11-10-2012, 05:22 PM   #9
Bennyhill's Avatar
Do all of you 5.0 owners burn through so much oil? My 4.6 never burn oil like that!
Bennyhill is offline   Reply With Quote
Old 11-10-2012, 06:18 PM   #10
DWC_SmOziLLa's Avatar
I run Royal Purple 5w-20 and a RP oil filter since I changed the factory slop out at 1500 miles. I now am at 6500 miles on my car and have 5000 miles on my last oil change. I have yet to burn a drop of oil. I thoroughly enjoy my 5.0 too, it is not babied at all.
Old 11-10-2012, 06:20 PM   #11
nitrous2v's Avatar
Region: Arkansas
For real!! I haven't heard anything about these 5.0's burning so much oil. My 4.6 is a non-issue in regards burning any oil between oil changes. Do I need to start checking the oil every 1500 miles??
nitrous2v is offline   Reply With Quote
Old 11-10-2012, 06:33 PM   #12
I try to check mine every 1000-1500 but it has yet to change. It's still good to check. And I always keep a quart with me because you never know.
Old 11-10-2012, 07:38 PM   #13
The Blue Dragon
Yea they so burn quite a bit, quite frankly I feel they should have gone with 5w30 in the motor to protect the engine and not 5w20 to help meet EPA standards
11:24 AM
