HID Foglight Problem - Mustang Evolution
Old 11-26-2012, 02:24 PM   #1
EthanGT03's Avatar
On my car I keep seem to having a problem with my HID fogs..
I had just replaced both of my bulbs because one was out, everything was perfect then a few days later the left one stops coming on, i replace the ballast, its back on a couple days and same thing..? I dont understand what it could be, any help is much appreciated!
EthanGT03 is offline   Reply With Quote
Old 11-26-2012, 02:27 PM   #2
Venomouz831's Avatar
I had the same problem with mine! My driver one went out I had to make sure very thing was connected good. But still it wouldn't work so I left it like that and all of the sudden it started working it was weird
)02 Gt, Founder of WE2G
Old 11-26-2012, 03:02 PM   #3
Same thing with one of mine and all of a sudden it started working again.
Ryan7racin is offline   Reply With Quote
Old 11-26-2012, 04:07 PM   #4
EthanGT03's Avatar
No one has found a solution even though all these people have these problems? Haha
Old 11-26-2012, 04:32 PM   #5
Coreyw428's Avatar
Region: Arkansas
Did you buy the cheap 1s or do you have digital ballast
Coreyw428 is offline   Reply With Quote
Old 11-26-2012, 04:37 PM   #6
Mine only did it like 2 days when it was really cold once they heated up it turned right on. Only happened them 2 days last winter
Old 11-26-2012, 07:51 PM   #7
thejohncarlson's Avatar
I have been told that the bulbs are almost never the problem. The ballasts are what usually fail. I have had one ballast go bad on mine already and they are about 6 months old.
thejohncarlson is offline   Reply With Quote
Old 11-26-2012, 08:42 PM   #8
MachMan1017's Avatar
Do you have a relay for them? Could be that you are drawing to much power and without a relay it doesn't get a sufficient amount.
MachMan1017 is offline   Reply With Quote
Old 11-26-2012, 08:47 PM   #9
lBRAlD's Avatar
Mine done that but always came on (2nd try) alternator wasn't putting out enough voltage. New alternator and new battery have not had a issue yet.
lBRAlD is offline   Reply With Quote
Old 11-27-2012, 10:07 PM   #10
1slosix's Avatar
lol i had that issue...just turned out to be a crappy ground...so i rerouted the grounds to the headlight ground points and i never had an issue again
carving corners like a boss
05:52 AM
