How to paint/color opinoin on brake calipers - Mustang Evolution
Old 12-06-2012, 09:56 PM   #1
MachMan1017's Avatar
Looking for a project in the near future, and a cheap one that appeals very well seems to be painting the brake calipers.
1. Best paint to use to paint? What I can see is it is the VHT hight temp brake caliper paint( of choice). Also do you use clear coat? Or only coats of paint?how many coats of paint? (3-6?)
2. Is it pretty straight forward? Jack it up, remove the tires and then clean with a wire brush.. And brake cleaner, then dry and start taping where you don't want it painted?
3. Your opinion for which color I should go with for the brake calipers on my car... Not just the colors shown (only for example)
Looking for as much information as possible, thanks in advance.
ID:	79649   Click image for larger version
MachMan1017 is offline   Reply With Quote
Old 12-06-2012, 10:42 PM   #2
Mile high JDF's Avatar
I painted mine using the G2 paint caliper kit. The steps go just like you listed them. The kit recommends letting the calipers dry for 24 hours before you drive it. I didn't use any sort of clear coat with mine. I know some people recommend clear coating though.
ID:	79661   Click image for larger version
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-06-2012, 11:43 PM   #3
svilla00's Avatar
I have used VHT in the past with great results. my DD had red calipers and the were still looking great 2 years later when I sold her.
svilla00 is offline   Reply With Quote
Old 12-06-2012, 11:51 PM   #4
Awesome! Yeah I really want to do this mod, need to get ahold of some floor jacks now lol.
What are your opinions on the color combo?
I'm leaning more towards red, not only because it's my favorite color, but because I think it's a much better color to stand out on the white car.
Old 12-07-2012, 05:19 AM   #5
jdavis96gt's Avatar
Region: West Virgina
I used high temp engine paint. I couldn't find anything close to moonlight blue except for engine paint. I sprayed in container than brushed on with foam brushes. I did about 3 coats. I didn't have to tape anything off either. For small/tight I used Qtips, worked awesome.
I heard not to use clear coat because it traps the heat.
Old 12-07-2012, 10:08 AM   #6
Finrdz's Avatar
I have never used clear coat on my brakes and have never had problems. I do use wax and grease remover to prep them after brake cleaner. some tire shine/ rim cleaner stuff can cause fish eyes in paint, so it is better to be safe then sorry
Finrdz is offline   Reply With Quote
Old 12-07-2012, 12:24 PM   #7
KARgt13's Avatar
You can use this G2 Brake Caliper Paint Systems
KARgt13 is offline   Reply With Quote
Old 12-07-2012, 05:02 PM   #8
If I leave the calipers on, there is no need to bleed the brakes is there? Just remove tire, tape up and paint?
Old 12-07-2012, 05:08 PM   #9
Finrdz's Avatar
That is correct, you aren't removing anything so you just have to unmask the stuff you covered and put your wheels back on and your done.
Old 12-11-2012, 03:04 AM   #10
1slosix's Avatar
i just used a can of spray paint i had left over from some side scoops i did years ago..after a year of being on the car nothings bubbled or chipped lol. about 15 minutes after painting i was back on the road too.
carving corners like a boss
Old 12-15-2012, 07:43 PM   #11
svilla00's Avatar
I would not recommend using regular spray paint. I would make sure to get a couple of cans of VHT. That stuff is good up to 900 degrees.
08:42 AM
