next mod for your 05-09 GT? - Mustang Evolution
Old 12-25-2012, 03:28 PM   #1
C_Dailey95's Avatar
so, it being Christmas, i got about 150 bucks from family. i decided to save it and have that be a decent start to my next mod. i cant decide between a few things though. what would you guys go with?
MGW short shifter
Ford Racing 4.10 gears
SR Lowering Springs
if i go with the gears, id wait and get the gears/tuner bundle. and if i go with the lowering springs, id get the springs and camber bolts and run them on stock shocks/struts until i can afford new ones. opinions?
C_Dailey95 is offline   Reply With Quote
Old 12-25-2012, 03:38 PM   #2
Sampey43's Avatar
Imo, i would go with the lowering springs before i went with 410s. Get the suspinsion work started to support the torque youll have from gears. Hope this helps
Sampey43 is offline   Reply With Quote
Old 12-25-2012, 04:03 PM   #3
Stang23's Avatar
For that money, I'd probably go lowering springs as well. Get rid of the 4x4 look
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 12-25-2012, 04:06 PM   #4
Venomouz831's Avatar
Lower it
)02 Gt, Founder of WE2G
Old 12-25-2012, 04:51 PM   #5
C_Dailey95's Avatar
Definitely helps. Im for sure going to lower it, thanks guys! And how long would you think i can run them on stock shocks/struts before replacing them?
Old 12-25-2012, 05:45 PM   #6
Stang23's Avatar
Well how many miles are on your car right now? You should be able to go a while on the stock struts. It just won't ride that great
340 RWHP
325 RWTQ
Old 12-25-2012, 06:45 PM   #7
BCS06GT's Avatar
If your over 50k on stock ones your wasting your money on lowering springs. Replace it all at once. Not to mention relocation brackets, camber plates, lcas, and adjust pan hard.
BCS06GT is offline   Reply With Quote
Old 12-25-2012, 06:56 PM   #8
C_Dailey95's Avatar
Im around 32-32,000. And i thought you only needed a pan hard bar if you go more than 1.5"?
Old 12-25-2012, 07:03 PM   #9
BCS06GT's Avatar
Depends, I'm lowered 1.9 in the rear and I could use one. For sure you'd want lcas w/ brackets to correct the suspension change. Even with 30k I'd still change the shocks and struts to something that is designed for a drop. Bolts suck too, get camber plates.
Old 12-25-2012, 07:38 PM   #10
Stang23's Avatar
I would say with that mileage your ok with just doing lowering springs for now if you can't afford to to shocks and struts. And definitely do camber plates over the bolts.
---------- Post added at 07:38 PM ---------- Previous post was at 07:36 PM ----------
Anything over 1.5" you'd want some lcas with relocation brackets and a panhard to get the rear end in line again
340 RWHP
325 RWTQ
Old 12-25-2012, 07:45 PM   #11
C_Dailey95's Avatar
Yeah i wont be on stock shocks/struts for too long. I graduate in june and my parents said i get a graduation present so i decided to go with car parts haha. the SR springs drop it 1.5". Would i be good without the lca's, relocation brackets, and pan hard bar for a few months? And ill definitly look into the camber plates, i only went towards the bolts since theyre cheaper and they have good reviews.
Old 12-25-2012, 07:52 PM   #12
Stang23's Avatar
Ya you'll be fine for a few months without that stuff
340 RWHP
325 RWTQ
Old 12-25-2012, 07:57 PM   #13
C_Dailey95's Avatar
alright cool, thanks for the help!
Old 12-25-2012, 08:19 PM   #14
BCS06GT's Avatar
If you do the bolts without the camber plates and then want to put plates it, you basically going to do the work all over again. Get plates if you don't want to do it twice,
Old 12-25-2012, 08:32 PM   #15
Caster Troy's Avatar
Region: Hawaii
+1 on the dampers but you don't need the camber plates unless you are gonna lower it 2 or more inches, the camber eccentric bolts will work just fine on a 1.5. inch drop.
Caster Troy is offline   Reply With Quote
Old 12-25-2012, 08:44 PM   #16
BCS06GT's Avatar
I'm maxed out of negative camber with the bolts with a 1.7 front and 1.9 rear drop. If I had to do it again I'd get the plates. I probably still will, or if you like buying tires prematurely, just get bolts.
Old 12-25-2012, 08:53 PM   #17
C_Dailey95's Avatar
you're dropped a bit more than i plan on going, it looks super nice though. what springs are you using?
but im still unclear, bolts, or plates? they both do the same thing one just does it more than the other. will i really need to adjust it that much to get plates with a 1.5 drop?
Old 12-25-2012, 08:57 PM   #18
BCS06GT's Avatar
I'm using the h&r springs. But I'm just saying if I had to do it again, I wouldn't had been cheap. The plates give way more adjustment than eccentric bolts. You'll get it close with the bolts, but the plates you'll get it perfect. Not to mention get rid of the pos strut mounts.
Old 12-25-2012, 09:09 PM   #19
C_Dailey95's Avatar
yeah i feel you. buy nice or buy twice right? i think ill end up going with the plates. itll take a bit longer but it should be worth the wait.
Old 12-25-2012, 10:43 PM   #20
Region: Hawaii
No, you won't. I have a 1.5 inch drop Eibach pro system springs & dampers with specialty tools eccentric bolts and my car is perfectly aligned. One thing you should get are GT500 strut mounts which are a lot stiffer than the OE ones, AM has them for around $110.
Old 12-25-2012, 11:19 PM   #21
BaSohol's Avatar
Gears all the way, my first mod was a CAI and tuner then 410s, go before show
2007 Ford Mustang GT 5spd
Old 12-25-2012, 11:55 PM   #22
Region: Hawaii
+ 1000
Old 12-26-2012, 10:34 PM   #23
MonteCitan's Avatar
10 rib setup was delivered saturday.. And thinking of getting a GT500/Boss 302 rear end
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Dropping in a 2000 gt motor Blackedout Pre-2005 V6 Mustang 20 02-07-2012 09:48 PM
2005 Mustang GT 350 Tribute Car (Mineral Grey Lovers) 2K05GT Pictures and Videos 8 02-01-2012 04:43 AM
2011 5.0 Next Mod Suggestions? doug5.0 2011-2014 Mustang GT 7 01-11-2012 07:28 PM
06:29 PM
