Homemade Catch Can - Mustang Evolution
Old 01-02-2013, 02:28 PM   #1
Rosco's Avatar
Homemade Catch Can
I was at lowes the other day getting a new garbage disposal and stainless steel line when I passed by the air compressor section and remembered that I'm still unprotected. So I bought a water/air separator, 2x 3/8 brass nipples, 3' of 3/8 fuel line, and galvanized brackets. All together it cost about $40. I had to remount the alarm, drill and tap the unit for brackets and bend the brackets to fit. All in all it took about 2 hours to do it the right way.
ID:	83808   Click image for larger version
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 01-02-2013, 02:30 PM   #2
1slosix's Avatar
looking good...alwasy better to make them then spend the cash to buy one pre-made
carving corners like a boss
Old 01-02-2013, 02:34 PM   #3
Rosco's Avatar
I also like the feeling when you complete a project you created. I think there's also some security knowing the quality of parts going into it as you picked them all.
Old 01-02-2013, 03:27 PM   #4
Sanguin's Avatar
I wish these new PCV valves were as small diameter as the old one. You have to use huge diameter hoses now...
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 01-02-2013, 04:24 PM   #5
IanM's Avatar
Wow, that turned out really well, great job! There's some great creativity!
2011 Grabber Blue GT California Special, 3.73 Gears, 6-Speed Manual, Steeda CAI, Steeda 93 tune, aluminum driveshaft (The Driveshaft Shop Co.), MGW shifter, Roush axle-back exhaust, Roush Side Rocker Panel Splitters, Ford Racing BOSS 302 front splitter, sound-tube delete, painted plug covers, JLT oil separator. Shelby transmission scoop & powder-coated trunk brace & many more items...
IanM is offline   Reply With Quote
Old 01-02-2013, 04:26 PM   #6
1slosix's Avatar
you know op maybe making a quick write up would be a good idea for those not knowing how to make them...
Old 01-02-2013, 04:31 PM   #7
Venomouz831's Avatar
That looks good!
)02 Gt, Founder of WE2G
Old 01-02-2013, 04:50 PM   #8
sinister07's Avatar
I'm stopping at Home Depot on the way home. Good job!
2003 Mach 1
sinister07 is offline   Reply With Quote
Old 01-02-2013, 04:58 PM   #9
v8pony's Avatar
+1000
2002 5spd GT
Feb 2013 Mustang of the Month
Old 01-12-2013, 04:21 PM   #10
Rosco's Avatar
Thanks! And thanks everyone else. I just got a strut tower brace and I'm in the process of painting that, the spark plug wire covers, and the catch can to match the car. While I'm doing this ill snap some pictures and make a write for you guys.
Old 01-14-2013, 11:37 PM   #11
BUSHGUTS's Avatar
Just make sure that you put a rubber gasket and a nut and bolt at the bottom of it. Those air to water seperators are designed to drip. I made the same very catch can out of that seperator once and i learned the hard way about them dripping.
BUSHGUTS is offline   Reply With Quote
Old 08-17-2015, 04:49 PM   #12
I just picked up one of these separators from Home Depot and I have a couple questions for anyone who has done this:
1) how do you mount the brackets onto the separator? I assume they are just bent sheet metal and mount to the firewall plastic with some self-tapping screws? But how do you secure them to the seperator? Doesn't look like there is nub room to drill and tap threads.
2.) what size bolt and gasket can I get to replace the drip fitting at the bottom of the clear cup?
Thanks in advance!
97cobraSVT is offline   Reply With Quote
04:00 AM
