1967 mustang please read detalis? - Mustang Evolution
Old 08-17-2009, 03:45 PM   #1
hi, i found a 67 mustang for sale, the ad said that the gears of been changed out to a lower ratio for more power. it has been set up for racing. then the part i don't understand, it said it has a bump shifter installed, i don't know what this is? what is a bump shifter (the car is an automatic) please help
macdaibhidh is offline   Reply With Quote
Old 08-17-2009, 03:56 PM   #2
It means that the car is an automatic, but has a manual valve body installed in it. The valve body is a set of passages in the transmission that change the gears by releasing the clutch pack when hydraulic pressure passes through them. A "manual" valve body is just that- you have to engage a mechanical switch to change gears. Thats where the bump shifter fits in. The shifter should have a spring loaded, ratcheting type of action that will pull on a cable connected to the transmission. Push the shifter forward you upshift, backwards you downshift. A properly built automatic transmission with a manual valve body will shift faster than having a standard manual and thats why they're popular in drag racing. If the car's got lower gears and a bump shifter, it's been raced and probably gotten the crap beaten out of it. You might wanna look for something else, something close to stock or all stock. A used car is already someone else's problem.
korey is offline   Reply With Quote
Old 08-17-2009, 04:16 PM   #3
The car is an automatic, but can be driven as a manual. There is no clutch, so to change gears you just "bump" or slightly push the gear shift to the side. The car will automatically shift for you, but you can do it yourself if you want. It can be fun to drive. I may want this car too
arlee is offline   Reply With Quote
Old 08-17-2009, 04:55 PM   #4
well this means no buttons to push just slap stick for racing.
jonni is offline   Reply With Quote
1967 mustang
» Members Mustangs
13 GT
lx92coupe
Lucy
Rawly
Add your Mustang
08:24 PM
