I have a 2005 Mustang. It leaks rain water into the passenger footwell. How do I fix this? - Mustang Evolution
Old 08-18-2009, 03:15 PM   #1
it might be from the windshield the gasket might not be any good
duran is offline   Reply With Quote
Old 08-18-2009, 04:00 PM   #2
A small pinhole leak in the windshield sealer will do that.If the glass has ever been replaced it's more likely.Check by removing the plastic cover over the windshield post and look for traces of water running down to the floor.
derrik is offline   Reply With Quote
Old 08-18-2009, 05:00 PM   #3
I would suggest to either take it to the Ford/Mustang dealership or take it to a garage and ask them to service it and check the problem that is occuring.
edoardo is offline   Reply With Quote
Old 08-18-2009, 05:40 PM   #4
All you need is some body filler or silicone, I would go with the body filler which you can buy at any auto store. This is an affective and cheap way of doing it.
delmon is offline   Reply With Quote
Old 08-18-2009, 06:26 PM   #5
are you sure it's rain water and not the drain hose for the a/c plugged up.
wilton is offline   Reply With Quote
Old 08-18-2009, 07:22 PM   #6
your heater coil probably went bad and its not rain water its water and antifreeze. Ive seen it 3 or 4 times on these cars
westbroc12 is offline   Reply With Quote
2005 mustang
09:52 AM
