Mustang mufflers fit? - Mustang Evolution
Old 08-19-2009, 02:45 PM   #1
i want to buy a muffler system from a 2007 mustang GT, and want to install it on my 1995 mustang v6, i was wondering if the muffler system would fit on it, thanks
wetherly is offline   Reply With Quote
Old 08-19-2009, 03:13 PM   #2
The muffler itself can probably be welded in. However the whole system will not fit at all, mainly because the mufflers on the S197 cars are behind the rear axle and in the SN95 cars they are located in front of the rear axle. The piping with the S197 will have different bends and probably won't fit on your car without significant modification. You're better off getting a system meant for your car.
coty is offline   Reply With Quote
Old 08-19-2009, 03:20 PM   #3
Unless you have a welder, don't even mess with it. I'm sure the bends are different and the pipe diameter may also be different. You will need to do a lot of adapting to get it right.
tedmund is offline   Reply With Quote
Old 08-19-2009, 04:04 PM   #4
Exhaust systems are a lot of work.
Talk to a muffler shop & they should be able to answer your questions & take care of your needs easier.
arlen44 is offline   Reply With Quote
05:53 AM
