I have 2 questions about MUSTANG car parts? - Mustang Evolution
Old 08-22-2009, 11:00 AM   #1
I have a 2007 V6 Mustang, and if I were to buy a "GT Drive shaft 2 piece with carrier and bearings", and a GT500 full exhaust kit, would this fit my car? Please don't complain about my car being a v6 just advice please thank you very much!
ronnie is offline   Reply With Quote
Old 08-22-2009, 11:11 AM   #2
the drive shaft wont woork. u could probaly modify the exhaust to fit but you will actually lose a lot of low end power. there is such a thing as to much flow in exhaust.
hristun is offline   Reply With Quote
Old 08-22-2009, 11:43 AM   #3
totally different animals
chaakmongwi is offline   Reply With Quote
Old 08-22-2009, 12:27 PM   #4
gil
there is no gain in planning this it will not work the drive shaft of the GT is slightli longer in height and the wider bolts then the V6 proboley exhaust you can get sumthing out of that but with a few modifications i dought you can put the whole exhaust in. look into flowmasters or borja you will get power out these with a v6
good luck
worked in parts department at A.A ford
gil is offline   Reply With Quote
Old 08-22-2009, 12:36 PM   #5
No.
sowingwa is offline   Reply With Quote
Old 08-22-2009, 12:37 PM   #6
on
What are you trying to gain by doing this. I am not beating you up for modding your 6 cylinder...that is your choice. Swapping driveshafts will not work because the 6 cylinder has a different transmission than the 8 cylinder. You would gain nothing by doign this though.
A GT500 Exhaust system would not work on your car because it is a 6 cylinder. It only has one exhaust pipe as opposed to the two that the GT500 has.
If you want an exhaust system for your car, go to an Exhaust shop and ask them to install one for you. It will cost about $500 and will sound decent as long as you use either Magnaflow or Flowmaster mufflers/
on is offline   Reply With Quote
01:02 AM
