91 towncar? - Mustang Evolution
Old 08-25-2009, 08:00 AM   #1
91 towncar?
4.6L 2V OHC will later mustang parts interchange
dubh is offline   Reply With Quote
Old 08-25-2009, 08:48 AM   #2
91 towncar?
Yes cylinder heads and most of the parts will interchange, if they are NON "Power Improved" style heads. Your '91 Towncar uses an aluminum intake, while Mustang intakes, and other Ford cars of post-'96 model year, use plastic intakes. The engine block however, will NOT interchange. This is because the '91 to early '92 model year 4.6L blocks used the same six-bolt bellhousing bolt patterns as the 3.8/4.2L V6 and 302/351W V8 engines. Mid '92 model years changed to the seven bolt style bolt patterns with the introduction of the AOD-E transmissions, utilizing the three bolt starters that every Ford technician hates having to remove. Hope this helps.
emmett is offline   Reply With Quote
Old 08-25-2009, 09:13 AM   #3
91 towncar?
2V not fuel injected?
Strange...
colbert31 is offline   Reply With Quote
Old 08-25-2009, 10:07 AM   #4
91 towncar?
It all demends on if it is SOHC or DOHC (the mustang that is)
If they are the same then yes absolutly they will, maybe not the lines but all of the hard part will
searbhreathach is offline   Reply With Quote
Old 08-25-2009, 10:22 AM   #5
91 towncar?
Not the back seat.
raimondo is offline   Reply With Quote
02:11 PM
