My heater is not blowing hot air?!? - Mustang Evolution
Old 03-03-2010, 12:30 AM   #1
bao
Ok i know there was someone earlier that asked this same question but my circumstance is a little different. My engine is brand new, including the thermostat, water pump and the radiator (along with other things). We recently added a coolant booster so that the engine runs a little cooler (for performance purposes), now my heater hardly blows any hot air unless im driving in a really high rpm (the car is standard, '99 mustang V6) is it the additive? or something else?
bao is offline   Reply With Quote
Old 03-03-2010, 01:02 AM   #2
you might try feeling the heater hose to see if they are hot. i,am thinking maybe it,s the heater core starting to plug up.
stanley is offline   Reply With Quote
Old 03-03-2010, 01:30 AM   #3
The tip is this is a new engine, or at least new cooling parts. Your cooling system needs to be bled, you have an air pocket. take the radiator cap off. let it idle for about 15 minutes and then check the coolant level. Turn off the engine and add coolant, including filling the overflow reservoir.
hobbard is offline   Reply With Quote
Old 03-03-2010, 02:28 AM   #4
why add a coolant booster?
all you had to do was get a lower temperature thermostat..
arrin is offline   Reply With Quote
Old 03-03-2010, 02:43 AM   #5
the first thing i would try is a new thermostat even if it is new some times new ones are bad
talmadge80 is offline   Reply With Quote
» Members Mustangs
Bella
sixpac
SGM
BigCiv
Add your Mustang
06:11 PM
