How to change blinker on Ford Mustang? - Mustang Evolution
Old 03-04-2010, 08:00 AM   #1
2001 Ford Mustang. How do I change the blinker? It is the blinker on the back of the car. (left side). I pulled a part some of the lining and there is some red button, and a few screws. Or if you know where i can take it to get it replaced for cheap.... I live in Oklahoma City.
columbanus is offline   Reply With Quote
Old 03-04-2010, 08:33 AM   #2
there are 3 11mm nuts holding the tail light assembly in place. remove the nuts and the assembly slides out. then just replace the bulb. takes about 10 minutes.
cleavon is offline   Reply With Quote
Old 03-04-2010, 08:58 AM   #3
Take it to any auto parts store they will replace it for you free. Don't forget to say thank you.
natal is offline   Reply With Quote
Old 03-04-2010, 09:36 AM   #4
you should be able to access the rear brake light housing from the trunk.
where the wires go into the housing, you should be able to turn and remove the light bulb socket, and replace the bulb.
burkett is offline   Reply With Quote
Old 03-04-2010, 10:05 AM   #5
go check your nearest auto zone checker or napa they can show you wat you need and help you replace it they'll charge for the bulb but not for the help to put it in and bulbs arent that expensive well then again i haven't boughten them in a while
birtingr is offline   Reply With Quote
Old 03-04-2010, 10:41 AM   #6
Read the instruction manual.
riki is offline   Reply With Quote
Old 03-04-2010, 10:55 AM   #7
ok this is kind of difficult to explain, but go to this site and do steps one and two, it will show you how to take off the taillight.
www.gtconcepts.net/mustang/instructionů
tedmund is offline   Reply With Quote
03:26 PM
