How do you put on the emblems for a 1966 Ford Mustang? - Mustang Evolution
Old 03-04-2010, 02:00 PM   #1
Do I just put the emblem adhesive on the back of the emblem or is there a part I need to put on it instead?
garren is offline   Reply With Quote
Old 03-04-2010, 02:19 PM   #2
Larry's right...older cars with studs coming out of the back side of the emblem had holes drilled in the sheet metal to the same stud pattern. They either used barrel clips which are small tubular clips that push in the hole and they have tiny little fingers that grip the hole and the studs on the emblems. Some emblems with larger studs used self threading nuts that held onto the studs from behind the sheetmetal. If you choose to, you can carefully snap off the studs and apply them with double faced tape made for that purpose although it's not correct. Just make sure they're in the right spot on the car and level.
giyn21 is offline   Reply With Quote
Old 03-04-2010, 03:02 PM   #3
Alot of your older cars had studs on the back side of the emblem. If yours doesn't, 3M makes a great 2 sided tape that most manufactures use today that is carried by most autoparts stores.
columbanus is offline   Reply With Quote
Old 03-04-2010, 03:32 PM   #4
If they are original emblems they used grip inserts that are pushed into the holes. Either you're adding extra emblems or someone previously filled the holes with filler before painting. Properly restored condition would require origanal equip.
meinyard is offline   Reply With Quote
08:04 PM
