What would be the best thing to buy to improve the performance on my car? - Mustang Evolution
Old 03-07-2010, 04:30 AM   #1
I have 1998 ford mustang automatic V6 engine 3.8 L. I would also rather go for the cheaper parts first and work my way up when i get more money.
bishamon90 is offline   Reply With Quote
Old 03-07-2010, 05:06 AM   #2
cold air intake, if not cold air intake get short ram intake. performance spark plugs, new exhaust system (performance headers, high flow cat converter and muffler), and other simple stuff getting replace will also help. fuel filter, higher quallity oil and oil filter, fuel system cleaner, new plug wires, etc.
imported_darrell is offline   Reply With Quote
Old 03-07-2010, 06:00 AM   #3
No matter what you buy, it won't make an appreciable difference in performance, unless you install a supercharger or turbo.
Anything you do to install something that you think is giving you more power will result in more fuel costs. You will tend to push the skinny pedal on the right down a lot quicker. Is it worth it at $3.50 a gallon?
If you want more power, sell it and buy one with a V8.
ethan is offline   Reply With Quote
Old 03-07-2010, 06:21 AM   #4
Your first mod should be a cold air intake setup with a K&N or similar style filter. It will give your car more power by allowing the engine to take a bigger colder gulp of air.
imported_raymond is offline   Reply With Quote
Old 03-07-2010, 07:07 AM   #5
cold air intake
better flowing muffler
get a tune up
make sure your tires are inflated properly
turbo (if you can afford it)
currito is offline   Reply With Quote
02:51 PM
