Why is my Mustang Over Heating?? - Mustang Evolution
Old 03-08-2010, 05:00 AM   #1
I have a 1994 Ford Mustang GT 5.0. I installed a new water pump and thermostat cause the water pump was leaking. It started to over heat a week later so thats when i just changed the thermostat. There are no leaks I beleive I have all the air out of the system. Im not sure what else it can be besides the radiator now. All of these parts are original. I have 109*** miles on the car. I just got the car not too long ago. It blows cold air when its turned on and hot air when its on. Any ideas?
quigley is offline   Reply With Quote
Old 03-08-2010, 05:17 AM   #2
when it over heats can you smell antifreeze? if all other ideas are debunked you may possibly be looking at replacing a head gasket, you maybe be having a small leak into your exhaust through the head, check for white smoke out of you exhaust, if there is any white smoke, go buy a new headgasket and put it on cause thats your problem
imported_darrell is offline   Reply With Quote
Old 03-08-2010, 06:17 AM   #3
cause you (or somebody) rode the pony a bit to hard laddy ...please explain "It blows cold air when its turned on and hot air when its on"??? ...that is just wierd!!! I run a 460 ci big block cause i like the power...
felippe is offline   Reply With Quote
Old 03-08-2010, 06:31 AM   #4
try boiling the thermostat with a thermometer to be sure it's opening at the right temp
garrett is offline   Reply With Quote
Old 03-08-2010, 06:51 AM   #5
did you make sure to add 50/50 water coolant?
wilton is offline   Reply With Quote
06:20 PM
