Subs and music cutting out?PLEASE HELP!!!? - Mustang Evolution
Old 03-09-2010, 09:45 AM   #1
i have a 1000 watt kenwood amp,2 channel,500w rms bridged at 4 ohms,190 rms x 2 @ 4 ohms,and 250 rms x 2 @ 2 ohms,i have a alpine s 300w rms 900 max,dvc 4 ohm,on one channel hitting 2 ohms,and on the other channel i have i have 2 12" sony xplod subs 380 rms,1300 max each,svc,4 ohm wired together,so thats 2 ohms,and when i first hooked them up they worked good then after like 30 minutes it cut off music and subs,then went back on in a couple seconds,then in 10 minutes after all cut off again,then back on is a couple seconds,then 5 minutes all cut off,went back on,it seems like each time i listen to it the cut off time happens sooner and sooner.also th amp has a built in cooling fan,only cuts out at at high volumes/ bassiest parts,amp is in my trunk,and i tried disconnecting just the sonys,so i was just using one channel for the alpine at high volumes/bass and didnt cut out,why is this happening?????//please help!!!!btw i have a 2000 mustang with a stock battery,and alternator,and no capacitor,4 guage wiring.
IF THIS KEEPS HAPPENING WILL I DAMAGE THE AMP??/
kolt is offline   Reply With Quote
Old 03-09-2010, 09:49 AM   #2
hey look at the amps fuse some times just because they look good dont mean they are good and also try hooking a hot wire into the radio remote wire goes you may need to put your own kill switch on it ive had to do this before also look at the ground wire
Branwel is offline   Reply With Quote
05:02 AM
