Single muffler or dual exhaust better for v6 mustang? - Mustang Evolution
Old 03-09-2010, 09:30 PM   #1
I have a 2008 v6 mustang and was wondering if it is worth the money to put a dual exhaust on it or it would be better to just stick with a single and get a high performance muffler.
neville is offline   Reply With Quote
Old 03-09-2010, 10:02 PM   #2
defiantly the duel exhaust.. speaking from experience dude you def want to get a magnaflow there the best... i have a v8 stang and i just put on a duel exhaust and it just makes the car sound and run better. Also if you got some extra cash getting some new headers while your doing the exhaust is not a bad idea. but the guy above me is right. the cheapest and most effective things you can do to get air into the engine are to get a cold air intake and if your feeling good i would suggest a 75mm throttle body and big lube tube it adds 18-20 horses and makes the exhaust sound that much better.
well good luck
sein is offline   Reply With Quote
Old 03-09-2010, 10:29 PM   #3
Dual 2.25" pipes were OEM on the GT Mustang, so a single 3 inch would be fine on your V-6. However, the problem with 3 inch exhaust is getting it bend over the axle without crushing it. Dual 2.5" pipes would definitely take away bottom end from your ride.
Short answer, one large pipe will flow as much as two smaller pipes.
Arleigh is offline   Reply With Quote
Old 03-09-2010, 10:48 PM   #4
well i would go with duils my self it will give it more power where it is got 2 pipes it can hndle more compresion.
imported_karsten is offline   Reply With Quote
Old 03-09-2010, 11:14 PM   #5
The first rule of making horsepower is getting the most air in and out of the engine. Go with the dual and you are on you way to solving half of the equation. ( just don't forget about the getting the air in part )
zen_stanger
jukka is offline   Reply With Quote
Old 03-10-2010, 12:08 AM   #6
Get a dual exhaust with a catted x-pipe, the power increase and torque are worth every penny.
wylingford is offline   Reply With Quote
Old 03-10-2010, 12:31 AM   #7
dual exhaust
beverleigh is offline   Reply With Quote
exhaust, v6 mustang
09:53 PM
