How to fix a program with an array of classes [C++]? - Mustang Evolution
Old 03-12-2010, 07:45 PM   #1
I am working on an array of classes so I can store some information that will be used later into my program. This is what I have for my array.
Car carArray[] = {Car ("Porsche", "911", "Silver", 2005, 50000),
Car ("Ford", "Mustang", "Red", 2007, 25000),
Car ("Voltzwagon", "Jetta", "Black", 2006, 16500)};
-- This is how I am calling it to check the information
cout << "Testing this array: " << carArray[0].getMake()
.getModel()
.getColor().getYear()
.getordervalue();
(had to split it up to make it show, or it would cut part of this line up.)
If I run it with just one of the .get, it will work. But once I add more than one, I get errors such as this.
&#039;getModel&#039; : is not a member of &#039;basic_string<char,struct std::char_traits<char>,class std::allocator<char> >&#039;
left of &#039;.getColor&#039; must have class/struct/union type
left of &#039;.getYear&#039; must have class/struct/union type
left of &#039;.getordervalue&#039; must have class/struct/union type
Kilian is offline   Reply With Quote
Old 03-12-2010, 08:34 PM   #2
Each of those method calls requires the carArray[ ] object instance. As shown, those after getMake do not have one.
cout << "Testing this array: " << carArray[0].getMake(),
carArray[0].getModel(),
carArray[0].getColor(), carArray[0].getYear(),
carArray[0].getordervalue();
Hope that helps.
jantis8 is offline   Reply With Quote
Old 03-12-2010, 09:28 PM   #3
you would need to refer to carArray[0].function for all method calls. not only the first one.
ann15 is offline   Reply With Quote
Old 03-12-2010, 09:58 PM   #4
I&#039;m not sure if the problem is as trivial as I imagined it, but did you try repeating the "carArray[0]" ?
like this:
cout << "Make: " << carArray[0].getMake();
cout << "Model: " << carArray[0].getModel();
if you want to combine them in one statement, do the following
cout << "Make:" << carArray[0].getMake() << " Model: " << carArray[0].getModel() << " Color:" << carArray[0].getColor();
This will NOT work:
"carArray[0].getMake().getModel().getC…
you have to specify on which object to call the function, for every function.
Good luck!
cipriano is offline   Reply With Quote
10:46 PM
