I have a 1992 mustang GT Can any one install a fuel pressure regulator or is a mechanic needed? - Mustang Evolution
Old 03-13-2010, 04:15 PM   #1
not a high performance part it is a stock part
ayawamat is offline   Reply With Quote
Old 03-13-2010, 04:39 PM   #2
It is fastened directly to the main fuel rail (on the return side of it) which supplies fuel to the fuel injectors. Should be attached with two bolts, probably having 7/16" or 1/2" diameter heads. It will have a small diameter, 1/8" approx. vacuum line attached to it from the intake manifold as well.
Very simple replacement, a manual is recommended for safety, but no adjustment is required for a stock replacement. Remember to relieve any fuel pressure that may be in the fuel rail before removing the fuel pressure regulator. There is a pressure relief valve (looks the same as the one for putting air in your tires) for this purpose also incorporated into the fuel rail, not far from the regulator.
collin is offline   Reply With Quote
Old 03-13-2010, 05:21 PM   #3
any one can. well it depends on your mechanical knowledge. get a chiltons and it will show you step by step directions
garren is offline   Reply With Quote
1992 mustang
04:37 AM
