How much horsepower does my 302 have? - Mustang Evolution
Old 03-16-2010, 01:00 PM   #1
I have a 302 that was fully rebuilt with forged flat top pistons,gt-40p heads(not ported),crane 1.7 roller rockers,speed pro cam(224* at .050 dur.,466" lift,110* centerline),edelbrock performer rpm,570cfm holley street avenger carb,pertronix flame thrower hei distributor,svo 9mm wires,1 5/8" shorties,off road h-pipe,pypes violator mufflers,march performance pulleys,electric fan.the engine runs great,idle is nice and lumpy,car pulls real hard,it's backed by a c-4 with a 3000rpm stall and 4.10 posi in a 79 mustang.just wanted some opinions on my estimated horsepower as there is no dyno's near my home and haven't found anybody that wants to try me,tks
howahkan is offline   Reply With Quote
Old 03-16-2010, 01:23 PM   #2
Probably 300-330hp at the flywheel depending what octane gas you use and where the timing is set. I have a built 289 in a '66 Stang with a little more cam and much better AFR aluminum heads(much better airflow than the Ford GT-40 heads) and I make about 360hp on 92 octane. You lose about 20% hp when measuring at the rear wheels. So 250hp at the rear wheels is probably more realistic.
ronnie is offline   Reply With Quote
Old 03-16-2010, 02:11 PM   #3
I am thinking you are around 300-350rwhp
shan57 is offline   Reply With Quote
Old 03-16-2010, 02:35 PM   #4
I would tend to agree with ragman. You'd see perhaps 20 more hp by stepping up to a 650cmf carb, the 570 is a tad bit small for your set up.
eoghan is offline   Reply With Quote
Old 03-16-2010, 03:00 PM   #5
If you're compression is under 10:1( I believe flat tops and 60cc GT40P heads make 9.5:1), you're wasting your money on 94 octane! I have a 340hp FRPP 302, 9.0:1 compression, and run 87 octane, 13.7@ 104 mph at 4000ft says I'm not hurting anything.
Other than that, I agree that you are in the 310 to 330hp at the flywheel.
fearghall is offline   Reply With Quote
Old 03-16-2010, 03:30 PM   #6
I would guess 250 give or take. But I'm not familiar with the cams and the carburetor numbers. I had two 5.0's an 86 GT and a 93 LX and stock they were about 215.
albion is offline   Reply With Quote
Old 03-16-2010, 03:33 PM   #7
I would say 240-250 horsepower at the wheels.
baldrick is offline   Reply With Quote
02:00 AM
