96 Ford Mustang Gt AC leak from service port - need help? - Mustang Evolution
Old 03-17-2010, 07:00 AM   #1
The r-134 service port on the passenger fender side and near the firewall pointing straight up with the black cap covering it. I found my leak problem is from there. It looks like a cylinder that can be removed and replaced with the service valve inside. I need help identifying this correct name and where can I find the replacement part on the net? There isn't a ford dealer near me... thanks...
imported_art is offline   Reply With Quote
Old 03-17-2010, 07:03 AM   #2
schrader valve.
.....core is a poppet valve assisted by a spring. Schrader valves are also used on the fuel rail of some direct fuel injection engines and on some refrigeration and air conditioning systems.....
http://en.wikipedia.org/wiki/Schrader_valve
botulf87 is offline   Reply With Quote
Old 03-17-2010, 07:15 AM   #3
it is not a schrader valve i can tell you that, go to your local ford dealer and most likely they can order it for you or you can call mps auto salvage(all mustang wreck yard) and they can get you the part.
lugaidh is offline   Reply With Quote
» Members Mustangs
mustang
svo
My Cobra
FordFan
Add your Mustang
04:22 PM
