So IT IS possible to put a 5spd in a Crown Vic...? - Mustang Evolution
Old 03-20-2010, 02:00 AM   #1
You will need to remove the old brake pedal assembly and (more than likely) fabricate a new bracket that holds a clutch and brake pedal assembly from a standard tranny car. (Look in a junk yard for parts that look like they will fit the available space under your dash.)
You will also need to find a manual tranny flywheel for your engine. (Automatics and manuals use different flywheels)
Then you'll have to match tranny mounting brackets (transmission mounts) to make sure the new tranny is properly mounted to the chassis.
The clutch linkage must operate freely without binding or hitting other under hood and under body parts.
The drive shaft may not be the right length as trannys differ in length.
The floor shift mounts will probably need to be modified from some found in a junk yard. (brackets, shifter, boots, seals, linkage, etc.)
Last you have to check the wiring diagram for any tranny mounted sensors that must be altered/disconnected/jumped to allow the ECU to get correct signals.
Lots of work and lots of time. (and lots of trial and error and last, lots of money!)
To be quite honest, it would be less expensive to have the automatic tranny tricked out. There are kits to change torque converter stall points and learning to shift an automatic like a manual, you can get about equal performance. 4th gear in the automatic is about the same ratio as 5th in the stick, so the top speeds would be similar.
All that was told to me in a Best Answer. But here's the question: My '92 CV has a 4.6 liter V8. Would it be just a little easier if I buy another 4.6 liter with a 5spd tranny out of a mustang and using the parts from it, rather than buying just a tranny alone and scavenging parts?
wolf is offline   Reply With Quote
Old 03-20-2010, 02:49 AM   #2
no cause you don't need to change the motor just the flywheel and a lot of the parts from the mustang don't just bolt on to your car its a custom job you will need to change computers and wiring harness and you need to check your rear end gear ratio cause no use going stick if the gears are to low and you bog off the line or to high and you end up shifting a lot to make up for the gears . you are looking at a very involved project that will suck a lot of time frustration and MONEY you also need to look at where the shifter well go you might have to get rid of the bench seat
finnegan is offline   Reply With Quote
04:09 AM
