What's the approximate HP gained to my Mustang 08 these mods? - Mustang Evolution
Old 03-20-2010, 12:15 PM   #1
I have a Ford Mustang 2008, 4.0L V6, Auto.
I know the stock mustang out of the dealer has 210HP.
I added the K&N Typhoon Air Intake System (part#69-3522TP)
and a
Borla axle back Muffler (part#11751)
what could it be the total HP gained?
charly is offline   Reply With Quote
Old 03-20-2010, 12:43 PM   #2
very little if any indeed. you may have picked up a few hp at the crank but nothing that will actually improve performance at the wheels (rwHP).
for a cold air intake to be effective it really requires:
1)a proper exhaust system -not an axle back...in your case full exhaust - catbacks with an x-pipe , true duals (like the new bassani for late model v6 mustangs...you can see the installation on you tube, just search "mustang v6 bassani"
2) headers and then
3)retune the engine management system with a tuner chip.
with those modifications you will pick up in the range of 15% increase over stock power and with the headers much of the power will get to the wheels making a noticeable difference in the drive....then if you install 3.73 gears in the rear end you will really be quite quick from the get go.
....your present installations are basically doing nil at this time and without performance exhaust and headers really a cold air intake is a waste of money.
cheers 04 cobra
rodel is offline   Reply With Quote
Old 03-20-2010, 01:17 PM   #3
probably around 5-10.
get it tuned (which you really want to do, as those 4.0s pretty much need a tune after a mod, even if someone claims it doesnt. you may be able to run for a little untuned, but it seems like people run into problems down the road) and you could realistically gain 20 or more
Unai is offline   Reply With Quote
Old 03-20-2010, 01:56 PM   #4
I want to say around 10-15hp.
aswynn95 is offline   Reply With Quote
Old 03-20-2010, 02:18 PM   #5
just a guess here but i would say 5-15 hp
kang29 is offline   Reply With Quote
08:31 AM
