2000 Camaro SS. Opinions on the parts i want to install.? - Mustang Evolution
Old 03-20-2010, 08:30 PM   #1
-Procharger 8+ psi w/ D-1SC Supercharger
-K&N Fuel Injection Performance Kit +14.7 HP
-Hotchkis Sway Bar Kit 1 solid rear, 1 7/16 hollow front
-Holley Throttle Body Assembly 90 mm
-American Racing Vintage Torq-Thrust M Anthracite w/ Mach Lip Rims (21.6 lbs)
-Pace Setter Long-Tube Headers 1 tubes 3 collector
-Magnaflow Cat-Back Exhaust System 3 tubing 3.5 tips
I'd also like to paint the body windveil blue clearcoat metallic (ford mustang color) and paint the roof black.
what do you think?
Nickson is offline   Reply With Quote
Old 03-20-2010, 09:16 PM   #2
Don't forget 40-55# injectors, the proper PCM tuning and a new clutch or a well built automatic(depending on the trans your car has).
You're going to want to do more suspension work too, the sway bar kit isn't enough.
Don't forget a good set of tires too, cheapy street tires will be worthless.
I have a P1-SC on my '89 GTA and it's a blast to drive, good luck!!!
Nevada is offline   Reply With Quote
Old 03-20-2010, 10:11 PM   #3
that procharger system is supposed to get it to about 512 HP + FIPK= 527+ long tubes& catback= 550+
dumont75 is offline   Reply With Quote
Old 03-20-2010, 10:25 PM   #4
i think it would be pushin over 500hp ! but if u paint it a ford color then your car will have very strange problems always going on . ever here of karma ? paint it black with a silver stripe down the bottm . ''intimidater'' !!!
stock ls1 = 330 hp .
+ supercharger = about 450 hp .
fuel inject kit = 465 hp
long tube header +catback = 500+ !!!!!
maximo is offline   Reply With Quote
Old 03-20-2010, 10:51 PM   #5
DUDE THAT CAR IS ALREADY BADASS!!!! I like honestly all of those parts and all friends use those parts and love them! So good luck. Sweet car!
primo is offline   Reply With Quote
Old 03-20-2010, 11:17 PM   #6
i think you have been hanging around that hot rod magazine parts list too much
culloden is offline   Reply With Quote
Old 03-20-2010, 11:50 PM   #7
if you did all that man, that would be one..bad...camaro!!! do it man and have fun! good luck with this road terrorizer!
panteno is offline   Reply With Quote
01:22 AM
