How much horsepower does a 1966 Ford Mustang have? - Mustang Evolution
Old 03-22-2010, 11:45 AM   #1
I am looking into buying a 1966 Ford Mustang from my friend and I was just wondering how much horsepower it was. I asked my friend but he didn't know. I could probally find it somewhere. But this is easyer. It is a 1966, coupe, 6 cylinder, automatic transmission, Ford Mustang. It is not a Shelby Mustang. Just a standard Mustang. It needs a little work, but the engine is fine. All orignal parts. Thank you!
brawley is offline   Reply With Quote
Old 03-22-2010, 12:28 PM   #2
200cid 1V 6-cyl 120 hp T Code
289cid 2V V-8 200 hp C Code
289cid 4V V-8 225 hp A Code
289cid* 4V V-8 271 hp Hi-Po K Code
289cid** 4V V-8 306 hp
289cid*** 4V V-8 390 hp
*Also available on Shelby G.T. 350
**Shelby G.T. 350-R
***Shelby G.T. 350S
ramzi is offline   Reply With Quote
Old 03-22-2010, 01:04 PM   #3
120 is new. No telling 40+ yrs later.
kevyn99 is offline   Reply With Quote
Old 03-22-2010, 01:56 PM   #4
120HP.
If it was factory supplied with a auto trans, it was one of 5469 of such built, out of a total of 607,568, so could be worth some money if in good condition.
panteno is offline   Reply With Quote
Old 03-22-2010, 02:29 PM   #5
120 hp. after 40 years, it probably has 90 horsepower. not kidding.
Displacement 200.00 CU IN. | 3278 cc. | 3.3 L.
Valvetrain OHV
Horsepower 120.00 BHP (88.3 KW) @ 4400.00 RPM
HP to Weight Ratio 20.7 LB / HP (Vehicles with similar ratio)
HP / Liter 36.4 BHP / Liter
Compression Ratio 9.2:1
Main Bearings 7
Fuel Type Gasoline - Petrol
Fuel Feed Carburetor
Holley 1-barrel carburetor
Block Cast-iron
donald is offline   Reply With Quote
Old 03-22-2010, 02:34 PM   #6
If you are looking into buying it.. DO IT! you can not really go wrong with buying a classic Mustang, ESPECIALLY if it is original! If all of the numbers are matching, then it is worth some money. If I were you can could get that car, I would do it!!! If you want something for hp, buy that, fix it up some, sel it, and then get something else, but that is definentially worth the time and money to have. If I were you I would fix it up and keep it, because the value will only go up, but do not let it sit around. If you do this, and still have it in another 10 years, I gaurentee you that you will be glad you went through with this! IM me at mustngs68, and I'll talk to you some more : )
Good Luck!
Prince is offline   Reply With Quote
04:23 AM
