Could someone please tell me is there a single fuse that works the fog lights in the 1996 Mustangs? - Mustang Evolution
Old 03-24-2010, 03:30 AM   #1
Hi. I do not have the car manual to see. When I first got the car I used the fog lamps one time. Since then they do not work at all. I find hard to believe if one fog light goes out the other fails as well. So other than wiring (which I haven't had that part looked at yet) I figure perhaps its a fuse. But is it separated from the other fuses or what? What color, or number?
Elishama is offline   Reply With Quote
Old 03-24-2010, 03:54 AM   #2
. If you plan on having this car for more than a yr, you might as well spend $20 and buy the manual on eBay. Or go to an auto parts store and buy the repair manual for $18. or both.
Cortland is offline   Reply With Quote
Old 03-24-2010, 04:46 AM   #3
I agree with Jay. Yes it is probably one fuse that controls the fog lamps. You need to get a haynes or chiltons manual and check all of the fuse blocks for the fuse it should be marked on the lid to the fuse block or on it something like that. Good luck!
schmaiah is offline   Reply With Quote
1996 mustang
11:45 AM
