2001 mustang heater core bypass? - Mustang Evolution
Old 03-25-2010, 02:45 AM   #1
Tye
is there any way to do this and if so does anyone have any articles with pictures or anything.
Tye is offline   Reply With Quote
Old 03-25-2010, 03:23 AM   #2
Disconnect both hoses from the firewall.Take a 2 or 3 inch piece of half inch copper pipe and connect the two together.Make sure and put on clamps and tighten then enough so they don't leak.It's easy to take apart latter if you need to.
Rhys is offline   Reply With Quote
Old 03-25-2010, 04:04 AM   #3
yes if you find the two heater hoses you car cut them and connect the ends to each other and the heater core will be out of the loop.. connect them at the moter sife not at the fire wall side.... look at heater it a 1976 ford f150 puckup find the heater hoses and you will understand...
thormond is offline   Reply With Quote
Old 03-25-2010, 04:30 AM   #4
you know you wont have any heat to defrost if you do this, this is very simple though, take one hose off the engine and connect the other end from the other hose to it. Make the engine have a loop in the hose.
derrik is offline   Reply With Quote
Old 03-25-2010, 04:39 AM   #5
Check with local auto parts store for parts, but you basically disconnect the hoses from the firewall, plug the holes and connect the 2 hoses.
duran is offline   Reply With Quote
2001 mustang
06:44 PM
