2008 Mustang v6 Auto is making a clicking noise From the middle of the engine ? - Mustang Evolution
Old 04-01-2010, 03:45 PM   #1
Okay well in the summer i turned on the car and it would be fine its winter know and i start my car and there is clicking Noise coming from the middle part of the engine im not sure what to do should i get the mustang changed someone help me
beverleigh is offline   Reply With Quote
Old 04-01-2010, 03:47 PM   #2
It's sound like a lifter is acting up when the engine is cold. To fix it right, you need to have the lifter changed out. Some times a good oil change will help this problem. But thing to remember is, if it's a 2008, I would take it to a Ford dealer for warranty work to be done on it. If you add anything to the engine, Ford can drop the warranty.
jakome is offline   Reply With Quote
Old 04-01-2010, 04:09 PM   #3
It' is probably normal fuel injector noise. The plastic intake manifolds seem to make the noise louder than what you would expect.
Arleigh is offline   Reply With Quote
Old 04-01-2010, 04:54 PM   #4
It sounds Like you are noticing lifter noise.....It is more noticeable in cold weather due to your oil being thicker prior to warming up the engine.
hassin is offline   Reply With Quote
Old 04-01-2010, 05:43 PM   #5
lifter noise. common with cold weather. seafoam it.
It'll fix her right up.
http://www.seafoamsales.com/motorTuneUpTechGas.htm
hobbard is offline   Reply With Quote
Old 04-01-2010, 06:26 PM   #6
It is probably going to blow up...try buying a more reliable car next time.
ruhleah is offline   Reply With Quote
2008 mustang
03:51 AM
