What do you do when you completely flush out a cooling system and the car still runs hot? - Mustang Evolution
Old 04-02-2010, 03:15 PM   #1
Dru
so i just flushed out my entire cooling system in my 89 mustang but she is still running hot. i'm thinking thermostat but i'm not sure. i need my car running good for a little car show going on here at 2:30P.M.
and by the way thanks for everyone that replied to the tune up question took care of all that today.
Dru is offline   Reply With Quote
Old 04-02-2010, 03:16 PM   #2
Bleed your coolant
With the engine running, remove the radiator cap, turn heater on as hot as it will go (max fan speed too) and watch the bubbles come up and pop. Now add coolant untill it appears full. For some stubborn bubbles, tapping on the upper radiator hose with your thumb will dislodge them. Continue adding coolant and letting the air bubbles escape like this untill it is full and no more bubbles come out.
dubh is offline   Reply With Quote
Old 04-02-2010, 03:32 PM   #3
well yank out the tstat and just see. you can also take the tstat and put it in a pot of hot water, at least 250 degrees and see if it opens
cormic is offline   Reply With Quote
Old 04-02-2010, 03:53 PM   #4
T-stat
clogged radiator
faulty water pump
clogged radiator hoses
Wrong mixture of coolant/water
Various things. Or it could be your cooling fans aren't turning on when they need to be.
Nickson is offline   Reply With Quote
Old 04-02-2010, 03:56 PM   #5
Could be thermostat, hoses or still plugged radiator as flushing it does not remove crud buildup.
randkin is offline   Reply With Quote
Old 04-02-2010, 03:59 PM   #6
yes a thermostat will make it run hot if it sticks closed or it could be the fan not working.
Jayar is offline   Reply With Quote
03:24 AM
