My brakes do not build pressure! Why? - Mustang Evolution
Old 04-06-2010, 07:15 PM   #1
There is no leak in the system, I have blead every line and no air is coming out, i've inspected all lines front to back, no leaks, but the system does not build pressure,
* Important Note * the Pedal does get pressure way down low, but does not sink! But pumping the pedal up does not build up pressure to a nice pedal height.
This is a 69 Mustang that originally had four wheel drum brakes. I've put a disk brake conversion on the front, the kit supplied a brake booster, master cylinder, front calipers, pads and rotors, I used the existing proportioning valve, and thus all other parts.
* Another Important Note * the car has sat now for 9 years, and the system was barely ever used.
Could the Master Cylinder be the problem? Thoughts!!
custennin is offline   Reply With Quote
Old 04-06-2010, 07:41 PM   #2
look on the top of your brake pedal for adjustment, you can change the length of pedal travel by adjusting into another hole if it's like a chevy.
Wren is offline   Reply With Quote
Old 04-06-2010, 07:48 PM   #3
Well, the master cylinder could need to be bench bled.
What's more likely, though, is that the rear brake shoes are not adjusted close enough to the drum. It takes a lot of brake pedal travel to make up distance to the drums. Once the shoes meet the drum, you will have a solid pedal.
Either that or the calipers aren't sliding on their guides. Same symptoms.
Berwick is offline   Reply With Quote
Old 04-06-2010, 08:46 PM   #4
Or are you pumping the system?
Did you bleed the master on the bench before installing it to the car?
What you should do is use a vaccum bleeder. this will solve all your problems.
trystan is offline   Reply With Quote
Old 04-06-2010, 09:05 PM   #5
I would change proportioning valve and re bleed system.
xavier is offline   Reply With Quote
Old 04-06-2010, 09:15 PM   #6
sounds like the seals in the master are no good
primo is offline   Reply With Quote
01:44 AM
