Will the Rear end out of a 1988 cougar xr7 fit in a 97 mustang? - Mustang Evolution
Old 04-08-2010, 11:45 AM   #1
i just blew my rear end and i have a courgar for parts i know that cougar has an 8.8 and my mustang is a 7.5. and also the cougar is 4 lug so will the shafts out of my mustang fit on that one.
meyer41 is offline   Reply With Quote
Old 04-08-2010, 12:02 PM   #2
Yes, you can use it... and yes, your axles will work.
The 8.8 housings in Fox Body Fords from the mid-80's up to '98 are virtually all the same. This goes for Mustangs, Capri's, T-birds, Cougars, Mark VII's... all except for the cars that got independent rear suspensions.
As I implied, the 7.5 axles are actually the same as the 8.8's in the 94-98 Mustangs, so you will be fine, there.
With regard to the suggestion that you use two same-side Ranger axles, that IS what some people need to use, but it is unnecessary in this case. The people that need to use those are people who are trying to switch their '93 and earlier Mustangs to 5-lug without making the rear track width any wider. In your case, you want to use your stock axles, so that you keep the same width that you had originally... like I said before. The Ranger axles would be shorter, which I doubt you want.
Hope that clarifies the situation some.
jack is offline   Reply With Quote
Old 04-08-2010, 12:31 PM   #3
Yes the rear ends should inter change, but the ratio's might be different. If you need 5 lug for your mustang you can use 2 left hand axles from a Ranger. Hope this helps
chadburn is offline   Reply With Quote
Old 04-08-2010, 12:53 PM   #4
The 1988 Cougar is a totally different car than the 1997 Mustang.. There are almost 10 years difference between the two.. my guess is no. If they were a year apart, I'd say probably.
Kellan is offline   Reply With Quote
Old 04-08-2010, 01:16 PM   #5
um yes
collin is offline   Reply With Quote
Old 04-08-2010, 02:13 PM   #6
from what i no yes
auley is offline   Reply With Quote
12:04 AM
