On a 1994 mustang gt unable to get the piston to compress? - Mustang Evolution
Old 04-10-2010, 02:15 PM   #1
have used tool to twist the piston, but the main part of the piston is not comressing
Dace is offline   Reply With Quote
Old 04-10-2010, 03:08 PM   #2
If it's turning, but not going back in, push in at the same time while you're turning. If the brake pads/rotors were way worn down, the piston may have come off the end of the jack-screw. Also, make sure you are turning clockwise.
Maichail is offline   Reply With Quote
Old 04-10-2010, 03:37 PM   #3
The piston for what? brakes , engine?
eljin is offline   Reply With Quote
Old 04-10-2010, 04:12 PM   #4
Check the ring land for any foreign material,check the ring size is correct,use assembly lube.good luck!
napier29 is offline   Reply With Quote
Old 04-10-2010, 04:36 PM   #5
Open the bleeder screw.
dumont75 is offline   Reply With Quote
Old 04-10-2010, 05:20 PM   #6
Engine or brake caliper? if brakes,and it has seized up,cover it with a penatrating fluid,and leave over night,and then try again,remember if your talking about brakes,once its back together before driving it pump the brake pedal a couple of times also when u push the piston back,unscrew the master cylinder top and mop up any leakage quickly.
jar39 is offline   Reply With Quote
1994 mustang
09:53 AM
