86 5.0 GT mustang or 86 2.3 SVO? - Mustang Evolution
Old 04-10-2010, 04:30 PM   #1
Trying to decide wich one of these cars to get.whats your take and why .Thank you
JosT is offline   Reply With Quote
Old 04-10-2010, 05:24 PM   #2
The GT gives you much more of a muscle car feel & sound, and the SVO is much more of a finese vehicle...quiet & shy, but can creep-up on you real fast. Check with a real authority as to which might be considered a better investment...I would only guess the SVO as Ford didn't make as many on that issue. But, I would say buy the one that has the most appeal to you-if you like red, and one is red, get it...or which is in the better condition...or if they'er both in terrible condition and this is a project vehicle, which can you get parts for the easiest might be a consideration as well.
adom is offline   Reply With Quote
Old 04-10-2010, 05:25 PM   #3
The SVO is a much better car with it's 4 wheel disc and 5 bolt wheels, it will out handle and out run the GT, plus its pretty easy to get 300 hp out of that little 4!
wetherly is offline   Reply With Quote
Old 04-10-2010, 06:02 PM   #4
They are both fun cars, but the SVO has the more modern look of the 87 GT's single headlamps plus it's Bi-wing spoiler. There is a lot of stuff out there for both cars, both used and new to make them perform better, not that they are slow or "horribly slow".
The 86 SVO came with 205 hp stock and a top speed of 140 mph! it is very easy to add adjustible boost and raise both of those figures
Mustang SVO makes its debut as a future-thinking alternative to the small block V8. Easy to distinguish from the rest of its third generation Fox brethren, the SVO features a grille-less swooping nose, large sealed-beam halogen headlights, an asymmetrical hood scoop and a biplane rear spoiler. The powerplant is a further departure. Utilizing an intercooled 2.3-liter turbocharged overhead-cam four-cylinder, the "machine" realizes 175 horsepower. The '85 and '86 models see increased turbo boost, a revised intake manifold, fuel injectors and exhaust flow take horsepower to 205 and 200 respectively.
Suspension and chassis are given considerable attention as SVO engineers seek balanced performance. Featuring Koni gas-charged shocks, 1.12-inch-diameter antisway bars, forged steel lower trailing arms, four wheel disc brakes and 16-inch wheels with P225/50VR Goodyear Gatorback radials.
Inside, the SVO is extremely well-accommodated. Included are: Hurst shifter, Recaro bucket seats, leather-wrapped steering wheel, dead pedal, 140 mph speedometer, 8000 rpm tachometer, turbo boost, water-temperature and oil-pressure gauges.
Road & Track lauds the SVO: "This may be the best all-around car for the enthusiast driver ever produced by the U.S. industry."
They are very collectible today and go for more money than a GT, They were produced for only 3 years, 84,85,86 with alittle over 9k built total, they were also the Special Vehicles Operations wiith later became the Special Vehicles Team, SVT
support groups on yahoo groups
http://autos.groups.yahoo.com/group/svoowners
jack is offline   Reply With Quote
Old 04-10-2010, 06:09 PM   #5
Both are horribly slow and unreliable at best, but because of collector status and how rare it is, I would buy the svo.
jeffery is offline   Reply With Quote
Old 04-10-2010, 06:47 PM   #6
i'd go with the 86 2.3. more rare. hell, why not be differant?
ighneachan is offline   Reply With Quote
Old 04-10-2010, 07:10 PM   #7
The 5.0's are much less costly to maintain as they are simple fuel injected engines and they get the job done. As with any turbo charged engine the chances of something going wrong with one of the components is higher due to the fact there are more things on the engine that can break. SVO's are more valuable and as mentioned probably a better investment if upkeep cost is not an issue.
jonni is offline   Reply With Quote
Old 04-10-2010, 07:54 PM   #8
Both are good. The 2.3l is a little better on the gas mileage. But the 5.0 has more top speed.
diwali is offline   Reply With Quote
Old 04-10-2010, 08:32 PM   #9
I've said it before and I'll say it again. There is no replacement for displacement.
bressal is offline   Reply With Quote
Old 04-10-2010, 09:06 PM   #10
5.0 GT Mustang is definitely the better one, it's faster and much more reliable, I've never liked the 2.3 SVO's very much.
zachary is offline   Reply With Quote
Old 04-10-2010, 10:02 PM   #11
86 GTs had a one off F.I. system that was replaced in 87 because it was crappy. SVOs are going to be valuable(how much so,???) someday as they were limited even then. There are lots of guys on the train of drag racing the 2.3L. SVOs make good candidates. They run in the 9s modded out and making lots of revs. Bottom ends are bullet proof.
raedford is offline   Reply With Quote
01:03 AM
