2005 mustang making a squeeling noise when the air is blowing? help!? - Mustang Evolution
Old 12-15-2011, 06:00 PM   #1
Tye
When im setting still it makes a chattering sound when the air is on but quits when I go down the road and sometimes when I stop it really gets loud squeeling
Tye is offline   Reply With Quote
Old 12-15-2011, 06:04 PM   #2
Sounds to me like you got a bad radiator fan bearing. Bring it to a mechanic. It may need to be replaced or simply just re packed with grease. If you know auto mechanics you can do this yourself. Invest $25 at your local auto parts store in a haynes manual. Trust me their life savers.
Harding is offline   Reply With Quote
Old 12-15-2011, 06:56 PM   #3
Pop the hood and see if the squeel is coming from the belt, maybe the belt is worn and slipping on the AC compressor. OR the AC compressor may be going bad and causing the belt to slip over it causing a squeel.
Ives is offline   Reply With Quote
Old 12-15-2011, 07:24 PM   #4
My wife makes that same sequel when I blow in her.
darwin is offline   Reply With Quote
2005 mustang
06:29 AM
