Hazy headlights? - Mustang Evolution
Old 01-06-2013, 02:08 PM   #1
MachMan1017's Avatar
Hazy headlights?
Best way to fix them?
Wannna help the girlfriend out.
MachMan1017 is offline   Reply With Quote
Old 01-06-2013, 02:16 PM   #2
Venomouz831's Avatar
Use a rubbing compound
)02 Gt, Founder of WE2G
Old 01-06-2013, 02:26 PM   #3
What all do I need? Will be my first time.
Old 01-06-2013, 02:33 PM   #4
People like to wet sand them but I use any rubbing compound and hit it with a gun with a ball on it
Old 01-06-2013, 02:38 PM   #5
I have nothing lol just moved back Texas.
So I only need sand paper and rubbing compound? Should i get 3 levels of grit? Like 500, 1,200, and 2,000? And just sand an wet sand? Then compound?
Old 01-06-2013, 02:39 PM   #6
I don't wet sand but some people do maybe someone will chime in. I used turtle rubbing compound
Old 01-06-2013, 03:47 PM   #7
fomoco4life's Avatar
Headlight restore kit....$10-15 at autopartsstore....has everything n it
Old 01-06-2013, 03:50 PM   #8
I actually found a video on using a sock, window cleaner, and tooth paste, worked great!
Old 01-07-2013, 04:58 AM   #9
taylor98gt's Avatar
I always use a buffer and rubbing.compound works great for me, and as far as those restoration kits go, most are junk, my friend bought 2 different ones and neither worked, I spend 10 minutes on them and they looked brand new
taylor98gt is offline   Reply With Quote
Old 01-07-2013, 05:51 AM   #10
jdavis96gt's Avatar
Region: West Virgina
If they're not real bad use some toothpaste.
Old 01-07-2013, 07:35 PM   #11
1slosix's Avatar
depends...if it's just yellowed and hazy then rubbing compound and a buffer. if it's microcracked then wet sanding first is a great idea. i've tried 5 headlight kits since i work at an autoparts store, and so far the best is the sylvania kit...comes with 3 grits, polishing compound, and a clear sealant. lasted my headlights a year before they microcracked beyond belief lol. gritty toothpaste is good...the cheaper the toothpaste the better btw..because cheap usually means gritty. turtle wax compound is good if you just wanna go that route
carving corners like a boss
Old 01-07-2013, 08:30 PM   #12
Region: Montana
Did mine yesterday with my porter cable, foam pad and Megs Plast-X. Looks great!
"OLD AGE AND TREACHERY WILL OVERCOME YOUTH AND SKILL"
manicrodder is offline   Reply With Quote
07:02 PM
