DIY: Catch Can - Mustang Evolution
Old 01-14-2013, 05:35 PM   #1
Rosco's Avatar
DIY: Catch Can
So after seeing that JLT makes one, but for newer models and for more than i would be willing to pay i decided to go ahead and make my own. Note that my pictures are from after install and my pieces are prepped for paint. You dont need to paint, i just got a STB and decided to paint both bright Atlantic.
Items: You will need a catch can that uses 3/8" inlet/outlets
You can get a plastic one, or a small one, but you will have to empty it more often. My catch can or CC is from Lowes and is an all metal cobalt unit that is hefty and a good size. $24
2 Brass nipples for inlet/outlet, 3/8 size. $8
Either brackets, or velcro to mount the CC to the firewall. The main deciding factor on what route you take is if you can drill and tap into the CC unit in order to mount brackets. You will also then have to use a bench vise to bend the brackets into the proper angle to mount to both the firewall and CC unit. Velcro is wayyyy easier but wont last and imo looks cheap. Thinking now if you dont have means to a tap set you could use epoxy to hold the brackets to the CC. Galvanized brackets wont rust and cost me $4
3' of 3/8'' fuel line. I only used about 2' but measure for your application. $4
Bolt and nut. Used to cap off the bottom of the unit, otherwise oil will leak you can use epoxy to seal the bottom as well. Had item
plumbers tape. had item
I had to remount my alarm to make room for CC but was able to utilize holes from it. I removed the filter that came with the unit, and put steel wool as a substrate for the oil to grab to.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 01-14-2013, 06:00 PM   #2
Rosco's Avatar
pics
ID:	85752   Click image for larger version
ID:	85754   Click image for larger version
ID:	85756   Click image for larger version
Old 01-14-2013, 09:09 PM   #3
sally2002's Avatar
Originally Posted by Rosco View Post
pics
Subscribed I've been looking for a post like this thanks
sally2002 is offline   Reply With Quote
Old 01-16-2013, 09:14 AM   #4
v8pony's Avatar
I want to do this so bad but still a but confused o exactly how to hook it up, this is a very helpful thread so subscribed but I gotta do more research just a bit confused
2002 5spd GT
Feb 2013 Mustang of the Month
Old 01-16-2013, 08:29 PM   #5
Rosco's Avatar
I'd be glad to help. Just tell me what's confusing you.
09:22 AM
