Flashing battery light - Mustang Evolution
Old 01-22-2013, 08:52 AM   #1
sLbxO143's Avatar
So after testing the battery the mechanic said it was fine, no battery light for 2 weeks & starts up fine. Driving on the highway today and battery light came on and stayed on. When applying the brakes the battery light would go off and then come back on..so flashing battery light now. I'm assuming its either a loose belt or the alternator on it way out. I'm thinking it has to be in the charging system where it's failing.
sLbxO143 is offline   Reply With Quote
Old 01-22-2013, 08:58 AM   #2
deadsp0t's Avatar
Sounds about right, or regulator. Any parts store can test all those things free of charge.
That's unimpressive
Old 01-22-2013, 09:04 AM   #3
KARgt13's Avatar
Yea I agree, if I had to guess I'd say the voltage regulator but obviously if it isn't then it's definitely the alternator.
KARgt13 is offline   Reply With Quote
Old 01-22-2013, 09:16 AM   #4
sLbxO143's Avatar
How much do the voltage regulator and alternator run for prices? And labor charges I know everywhere is different just trying to get an idea.
Old 01-22-2013, 09:17 AM   #5
It's probably gonna be your alt. Not sure on prices. It's located in a very easy place, just replace it yourself
Old 01-22-2013, 10:48 AM   #6
sLbxO143's Avatar
I have someone that can do it for me for free but I don't know how soon they can do it and idk how long the alternator will last. Have to drive 60 miles every day to school so not trying to push it.
Old 01-22-2013, 10:50 AM   #7
If it is the alt it will leave you on the side of the road in a hurry...
Old 01-22-2013, 11:01 AM   #8
KARgt13's Avatar
An alternator is around 130-150 new (I think), and less for a rebuilt one. And if I'm not mistaken, the voltage regulator is inside of it, so either way you have to buy an alternator. I don't think the swap should be too difficult, the hardest part is the belt.
Old 01-22-2013, 11:18 AM   #9
sLbxO143's Avatar
Yeah so going to have to pay for labor costs and will fix tomorrow.
Old 01-22-2013, 11:31 AM   #10
1slosix's Avatar
it's such a simple swap though...basic hand tools is all you need. i did mine in a parking lot in the dark lol using my cell phone for light
carving corners like a boss
Old 01-22-2013, 11:37 AM   #11
sLbxO143's Avatar
Ill see if my dad can help me lol, where can I just buy an alternator though? Through like ford or what?
Old 01-22-2013, 11:38 AM   #12
Venomouz831's Avatar
You can get one at you're local auto parts store
)02 Gt, Founder of WE2G
Old 01-22-2013, 11:38 AM   #13
sLbxO143's Avatar
Ok will check out tonight and see what's going on
Old 01-22-2013, 11:46 AM   #14
KARgt13's Avatar
Autozone or advanced auto parts will have new and rebuilt ones more than likely in stock.
Old 01-22-2013, 11:46 AM   #15
Yea or I think they can just order it for you from there
Old 01-22-2013, 05:09 PM   #16
sLbxO143's Avatar
Just had alternator and battery tested. My alternator is testing 14.26V no load and then under load it tested 14.17V. Battery voltage was 12.75V and measured at 504 CCA and supposed to be 610 CCA ..which is good but not perfect. But the problem is the starter which the voltage was 11.32V but at start-up fell down to 7.9 amps so low cranking amps. So I guess the battery light is jus an idiot light lol.
Old 01-22-2013, 05:22 PM   #17
Jayjay's Avatar
I had the same issue, sometimes the alternator is failing and sometimes it works as it should. Mine tested fine but further testing then it show it was failing at times.. Been replace as we speak.
Jayjay is offline   Reply With Quote
06:21 PM
