power window problem HELP !!!!! - Mustang Evolution
Old 07-06-2008, 08:43 PM   #1
wvstang5.0ho's Avatar
Region: West Virgina
Ok guys need help here, Got in the car tonight (94 GT) rolled the windows down, got to the store rolled them up everything was fine came out and once again rolled them down well when I got home went to roll them up, pass side went up fine tryed the drivers and nothing, but noticed the lights dimmed for a second and the radio kicked off and then right back on again, everytime I touch the button the radio goes off for a second and the lights dim a little, only for a second tho I can hold down the buttom and the radio and lights will go back to normal. Drivers window motor is only like 3 months old, could there be a wire loose on the motor or what ? Please any help would be greatly appreciated.
thanks
Brandon
wvstang5.0ho is offline   Reply With Quote
Old 07-06-2008, 09:12 PM   #2
Spark Plug's Avatar
Re: power window problem HELP !!!!!
sounds like a short in the wiring, get a schematic and see what those two circuits have in common, might have to end up just manually tracing the wires down, also check your power and grounds at the swtich, could let ya know if it's a short to power or to ground
Spark Plug Racing- "If it Breaks It Was Meant To Be Upgraded
2003 Dodge Ram HEMI
2008 Suzuki Kingquad 750 4x4
Spark Plug is offline   Reply With Quote
Old 07-06-2008, 09:18 PM   #3
Great thanks alot, I'll check into that.
Old 07-08-2008, 12:27 PM   #4
03 mustang GT
Send a message via AIM to kcfan_2004 Send a message via Yahoo to kcfan_2004
thats too funny. My drivers window motor just went out in my 03 GT like 3 days ago. However, I know its my motor. Anyone know if they are hard to replace yourself? Or would it be best to have ford do it?
kcfan_2004 is offline   Reply With Quote
Old 07-08-2008, 12:35 PM   #5
sounds like cajun...only his driver window will start rolling up but stops about 4" short and just continues to try like the gears are slipping.
Old 07-08-2008, 08:31 PM   #6
Well found my problem today, when who ever replaced the window motor they didnt tuck the wires to good and one of them was rubbing against a sharp piece on the door and it was shorting it out. So I took it out and run new wire and tucked them a little better and made sure they were far away from anything that would cause this again and I even checked the other door just incase. And yes it is a PITA to change the PW motor I had to take mine out to repair the wires and it sucked. But thanks everyone for the help.
Old 07-08-2008, 08:35 PM   #7
Spark Plug's Avatar
told ya so.
sorry couldn't resist. as a side note i also have a short in my wiring for the windows as well, only work when the door is in the perfect position. LOL
2003 Dodge Ram HEMI
Old 07-08-2008, 08:56 PM   #8
told ya so.
yep you sure did and I thanks ya for it.
power window not working rob913 1979-1995 Mustang GT 5 08-21-2010 11:28 AM
1994 Power Window mepkjp2822 General Mustang Discussion 0 06-26-2010 07:19 PM
Power Window Leonard 1996-2004 Mustang GT 3 09-03-2009 08:07 AM
window problem !?! help! carlosc Pre-2005 V6 Mustang 14 02-22-2009 05:27 PM
Power window and lock problem need help blzfan1963 Pre-2005 V6 Mustang 3 08-08-2008 06:35 AM
11:38 AM
