Would u buy? - Mustang Evolution
Old 02-06-2013, 03:37 PM   #1
Krisis187's Avatar
Region: Nevada
Would u buy?
Would you buy 2011 mustang v6 salvage title for under 2000?of course there's big damage tho
ID:	89550   Click image for larger version
Krisis187 is offline   Reply With Quote
Old 02-06-2013, 03:53 PM   #2
2300turboford's Avatar
Yeah and would repair it sell it and buy me a termi
Old 02-06-2013, 03:54 PM   #3
Venomouz831's Avatar
Maybe you can buy it and part it out for more
)02 Gt, Founder of WE2G
Old 02-06-2013, 04:43 PM   #4
Krisis187's Avatar
Region: Nevada
That's what I was thinking lols how much u think I could piece it out for
Old 02-06-2013, 04:48 PM   #5
Bong Toke Bobby's Avatar
Thats just sad to see..
Bong Toke Bobby is offline   Reply With Quote
Old 02-06-2013, 05:01 PM   #6
Krisis187's Avatar
Region: Nevada
I kno
Old 02-06-2013, 05:31 PM   #7
My guess is that it has serious frame damage though.
Old 02-06-2013, 06:15 PM   #8
Krisis187's Avatar
Region: Nevada
I was thinking that two cause I had a few to choose from but the other has water damage Didn't kno if I should mess with it...
Old 02-06-2013, 09:03 PM   #9
Sanguin's Avatar
The engine is worth a thousand or more, same for the tranny. Anything else you sell (interior, front end pieces) is gravy.
Water damage cars are going to be harder to sell as parts, but easier to sell as a full car if you intend to repair it. Just don't run it or hook a battery up to it until its drying and the things have been flushed.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 02-06-2013, 09:52 PM   #10
Krisis187's Avatar
Region: Nevada
So if its water damaged u could still use it?? And what do u mean flushed? Also how do u kno if its fully dry?
Old 02-06-2013, 10:21 PM   #11
Sanguin's Avatar
Water damages means its been sitting in water. Usually they specify fresh or salt, salt has corrosion issues.
You make sure it's dry by stripping the vehicle and checking every nook and cranny. Probably have to cause the floorboard will have sediment and crap settled in it you'll need to clean. Keep a fan and some heat on it if you can. You'll also need to check the circuits for shorts too after everything is dry. So you better learn how to check for amp draws.
Flush the engine and transmission by draining all their fluid and pumping new through them. For the engine, drain and fill it a few times with new filters. For the trans, it depends. Manual will be similar to engine. Auto, you'll need to drain and fill it and disconnect a trans hose and start the engine and let it pump all the fluid out. Do this a few times and replace the filter inside. This will make sure no water lingers inside and in the torque convertor. You'll need to drain and refill the rear diff too, just in case.
Most engine connections are waterproof. It's usually interior gismos that take the most damage circuit wise.
Old 02-06-2013, 11:31 PM   #12
Jedimindtricks's Avatar
looks to be a lot of good working parts just from the pics, and I am sure that it's good working interior parts as well. I would say front bumper the finders and the front grill, headlights and engine components to include tranny and links and headers or whatever else might be under the hood. Very worth the $2000 to scrap, but if you plan to keep it the frame it totaled and you would need to by a new frame/Shell, but the coast of doing that is not cost effective.
Jedimindtricks is offline   Reply With Quote
Old 02-06-2013, 11:35 PM   #13
Krisis187's Avatar
Region: Nevada
How would I learn about amp draws
Old 02-06-2013, 11:48 PM   #14
Nate98stang's Avatar
I'd def buy it if it can be bought for 2 grand, that's a steal in my opinion, easily part it out make good money, then scrap the rest. Or fix it and sell for a good amount
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 02-06-2013, 11:51 PM   #15
Krisis187's Avatar
Region: Nevada
How do u scrap it out
Old 02-06-2013, 11:55 PM   #16
Well around here you can go to scrap yards and they give u what it's worth on weight of the metal, normally u get like 200-300 for a car but u can take off anything u want to keep to sell
Old 02-07-2013, 12:16 AM   #17
Krisis187's Avatar
Region: Nevada
You thibk thy do that in las vegas?
Old 02-07-2013, 12:17 AM   #18
Honestly have no idea buddy, but heck parting it out has got to be worth it, and somebody might buy the shell once u strip it u never know
Old 02-07-2013, 12:20 AM   #19
Krisis187's Avatar
Region: Nevada
Tru thanks bro
Old 02-07-2013, 12:23 AM   #20
Tru thanks bro
No prob man, good luck if you decide to buy it
07:07 PM
