Question - Mustang Evolution
Old 02-06-2013, 06:14 PM   #1
Krisis187's Avatar
Region: Nevada
Question
If u had a 1970 mustang gt could u put a 2011 engine inside it??
Krisis187 is offline   Reply With Quote
Old 02-06-2013, 08:06 PM   #2
Termi's Avatar
With $$ you can do anything to a car. You could do it but it'd be expensive.
Termi is offline   Reply With Quote
Old 02-06-2013, 08:33 PM   #3
Krisis187's Avatar
Region: Nevada
I have 4 Gs and I can get the engine from this car that's total for like 400 and 1970 that has bad engine for a 1000 so u think I could get it installed with the rest of the money?
Old 02-06-2013, 09:00 PM   #4
Mkolabin's Avatar
Wouldn't you still need to look at a new rear axle? Trans?
I'd be surprised if, at 4 grand all in, the car you'd come away with would be any good as a driver.
2006 V6 - Black on black. Tints, Louvers, Shorty Antenna and BBK CAI. "We're just getting started folks!"
Mkolabin is offline   Reply With Quote
Old 02-06-2013, 09:17 PM   #5
Termi's Avatar
[QUOTE="Krisis187;1513890"]
I have 4 Gs and I can get the engine from this car that's total for like 400 and 1970 that has bad engine for a 1000 so u think I could get it installed with the rest of the money?[/QUOTE i think so, if you take the computer tranny and everything else required from the totaled car.
---------- Post added at 10:17 PM ---------- Previous post was at 10:13 PM ----------
Maybe think bout seeing if justa taking the body off the new mustang and fix frame damage and whatnot (if any) then stick the body of the old one onto it. Might work out better. If thatd be possible
Old 02-06-2013, 09:54 PM   #6
Krisis187's Avatar
Region: Nevada
That's a good day
Old 02-07-2013, 11:30 AM   #7
claudermilk's Avatar
Short answer: yes. I've seen a '65 with a Coyote swap & it was sweet. I am certain they spent far more than the $4k you mentioned to do it.
Can you get the transmission, computer, wire harness, axle, etc. off that car as well? I'd try to get everything you can if you decide to try this.
claudermilk is offline   Reply With Quote
Old 02-07-2013, 12:36 PM   #8
Cobrarunnin9s's Avatar
I highly doubt you will be able to attain a mildly used coyote engine for $400 even from a total. Take off engines run over 6k by themselves and you still need the trans and CPU/harness as well. Plus all the other things you need, your looking at 10k minimum and that doesn't include labor if you can't fabricate what you need yourself.
Cobrarunnin9s is offline   Reply With Quote
06:30 AM
