What should I use to clean the throttle body? - Mustang Evolution
Old 07-13-2008, 11:04 PM   #1
I was wondering how i should go about cleaning the throttle body on my 95 mustang. Above the TB it says not to use cleaners because the TB is coated in a special coating. But then again my throttle body has alot of black build up on it what should I use to clean it?
blue95stang is offline   Reply With Quote
Old 07-13-2008, 11:13 PM   #2
Re: What should I use to clean the throttle body?
You can pull the IAC off the side of the throttle body and use a cleaner at that point. I wouldn't scrub anything too hard, just use something like a electronics cleaner (milder than a carb cleaner) and let it do the work for you. I've used no contact electrical cleaner to clean all those parts and haven't run into any problems.
Old 07-14-2008, 09:58 AM   #3
Herbstang's Avatar
Old 07-14-2008, 10:07 AM   #4
Originally Posted by Herbstang View Post
exactly right... thery make a mass air and tb cleaner to that is safe.
SimplyOrange is offline   Reply With Quote
Old 07-14-2008, 10:10 AM   #5
Herbstang's Avatar
Do I get a prize
Old 07-14-2008, 10:37 AM   #6
Do I get a prize
Old 07-14-2008, 02:25 PM   #7
Kiljosh's Avatar
MASSIVE COOKIE
Old 07-15-2008, 06:35 AM   #8
doesent it look delicious? that cookie is a post whore too
Old 07-15-2008, 08:12 AM   #9
Herbstang's Avatar
Damn That will fix the munchies !!!
throttle body ? wvstang5.0ho 1979-1995 Mustang GT 16 07-29-2008 10:48 AM
throttle body kingboy23 2005-2010 Mustang GT 7 05-06-2008 06:31 AM
throttle body sonicpony Pre-2005 V6 Mustang 2 09-09-2007 12:23 AM
70 or 75 mm throttle body????? greg_g70 1996-2004 Mustang GT 9 12-20-2004 09:58 AM
throttle body Murph00 Pre-2005 V6 Mustang 5 11-26-2004 11:43 PM
02:01 AM
